09-19-2016 11:41 AM
Here is an interesting problem:
I have a 1 year old factor reconditioned 7D EOS I use exclusively for video recording which I typically shoot at 24fps..
Recently (ON ALL SHOOTING MODES) it automatically reverts to 1 minute shut off and 30fps. (it may revert to other defaults as well, but nothing that effects my shooting or that I've noticed.
Each time I turn it on, I must reset the fps, and the shut off time (to OFF or 30 minutes or whatever) - but then the next time I turn it on, it has reverted back to 1 minute shut off and 30fps.
Also, sometimes, even without shutting the camera off, it will automatically revert to 1 minute shut off, and shut itself off.
Note again, it does this on EVERY mode, even photography and custom modes.
A friend told me to try CLEARING all custom functions... but when I try that, I get a message that says:
"cannot clear Custom Functions.
Select a shooting mode other than C1, C2, or C3"
The weird thing is I get the same message in MANUAL mode, or any other mode.
I also tried removing the clock battery, but the only effect that had is I had to resent the date and time.
Note: Firmware is 2.0.5
HELP!
--Pete aka Todd00009
09-19-2016 12:31 PM
Yes, the LCD matches the knob.
You can tell the knob works because the menu settings change...
but no matter what I set them to... when I turn the camera off... it reverts back to 1 minute auto shut off and 30fps.
09-19-2016 12:44 PM
If you are in "M" mode and when you try to clear the special functions settings you get the "Can't 'cos I am in C1, C2 or C3 mode", The camera is broken and needs repair.
09-19-2016 12:47 PM
well, unfortunately, that's what I am thinking...
but before I send it for repair, I figured I'd ask you guys first!
Thank you very much
09-19-2016 01:07 PM
The camera cannot clear settlings that are currently in use. Try to put the camera into Green "A" mode, and then clear the functions.
09-19-2016 01:20 PM - edited 09-19-2016 01:21 PM
I will try that.
I will also try replacing the battery.
But I fear the worse... the camera requires surgery.
The good news is, last week I purchased a 70D which is GREAT!
But I'm not ready to retire this 7D yet... as I still need it as second camera for my film shoots.
Thanks again, for all of your suggestions and support!
09-19-2016 01:28 PM
@Todd00009 wrote:Here is an interesting problem:
HELP!
C1, C2,, and C3 automatically revert to the last setup saved in C1, C2, and C3.
Go to the menus and save your settings to C1, C2, aor C3 and they will always be there in the future.
Otherwise, use P,Tv.Av or M modes and your last setting will be saved.
09-28-2016 01:06 PM
To all of those who helped solve my problem.
My problem was the camera was auto-reverting to default settings.
(the most annoying was it was reverting to a one minute shut off time).
It turned out the clock battery needed replacing.
I had no idea a bad clock battery would have such a profound effect on all other camera functions.
Thank you again,
PETE
09-28-2016 02:20 PM
Thank you again,
PETE
WOW! That would have been pretty low on my list of suspects, too. How does my 60D get by without a seperate clock/memory battery? Thanks for the follow-up, and kudos to Diverhank.![]()
09-28-2016 04:29 PM
@BurnUnit wrote:
@Todd00009 wrote:It turned out the clock battery needed replacing.
Thank you again,
PETE
I can't speak to the 60D in particular. (I've never even seen one.) But cameras that don't have a clock battery usually have capacitors that are charged from the main battery. The advantage of this approach is that there's no second battery to go dead. The drawback is that the capacitors won't stay charged as long as a battery would.
09-28-2016 06:44 PM
Thank you again,
PETE
If the software is interupt-driven, then a dead and dying clock is analogous to a dead heart.
