02-20-2026
12:13 PM
09:27 AM
James_C
Autofocus works correctly 95% of the time, but occasionally seems to lose contact with lens and switches to manual focus. RF 24-70 is my main lens (although also have had similar issues with two EF lens using Canon EF-EOS R adaptor - shows me that issue is with camera, not lens).
Is this something a new firmware update might correct?
02-21-2026 11:42 AM
As long as your mount is tight, this seems like a service issue.
02-21-2026 12:52 PM
This is an interesting report since it's not physically possible for your RF 24- 70 f2.8 to "switch" itself from AF to Manual mode on its own.
As of this posting v1.2.0 is the latest firmware available for the R5 mark II. Note, firmware updates should not be performed on a body which is malfunctioning, or exhibiting unexpected behavior as it can mask or further compound your issues.
If you have any accessories connected to your camera besides a Canon EF to EOS R adapter, they should be removed during troubleshooting.
Since you have performed a factory reset and hopefully retested without making any modifications except for setting PIN, time and date, I suggest you reach out to Canon support.
MyCanon
https://myprofile.americas.canon.com/us/signin
Register your body first in the MyCanon portal, then call support.
1-800-652-2666
02-21-2026 03:21 PM
My colleagues, those guys are wise! I would only add to make sure that all wireless communications are disabled if you are not using them.
