04-04-2018 06:01 AM
In the menu settings it is necessary to select either AF face recognition, AF Flexizone multipoint ( ) or singlepoint [ ]. I usually shoot using single point focus but occasionally multi point. Will multipoint ( ) cover both situations or do I have to go into the menu every time I wish the swap between single and multipoint - I assume that selecting single point will prevent being able to use multipoint focus. The manual does not give guidance.
05-27-2018 06:11 PM
Hello Mike 21,
Multi-point would not be used to cover both situations, as the single-point uses just one point to pinpoint focus. We would recommend selecting whichever one will work for the specific scene at hand.
05-27-2018 07:45 PM
You don't have to use the menus all the time. Does the focus mode button on the top of the camera by the shutter button do what you want?
05-28-2018 12:38 PM
Thanks for your replies. I have now settled using single point focus all the time and find it works more consistantly than using multi-focus - rather like using a rangefinder camera.
05-28-2018 03:36 PM
I like using the center section focus that has about 6 points in the center of the frame.
