03-20-2017 03:19 PM
03-20-2017 05:16 PM
Wow...tough problem to have. The only thing I can think of is that you had too many things (noise reduction) turned on and the camera was too busy saving the files (buffer filled up). Even without the noise reduction options, this happens to me sometimes when I was shooting birds at 10fps in RAW mode.
The worst reduction is the "Long Exposure Noise Reduction", it slows the camera down to a crawl. I'd turn off all selectable noise reduction and retry. If this doesn't work then there's a problem with the camera...
03-20-2017 09:46 PM
Goofy behavior frequently seems to go hand in hand with unreliable memory cards.
Use just one memory card, until you can nail down what the fault could be. Never use micro-SD cards, because the adapters are unreliable. Always perform a "low level format" on a "new" memory card in the camera prior to first use. Always. Stick to name brand cards: like Sandisk or Lexar.
03-22-2017 01:21 PM
Thanks, Diverhank, but Long Exposure Noise Reduction was already turned off. After more testing today, I was able to shoot about 400 images at 10 fps with no problem. I let the camera rest for 5-10 minutes and then all of the problems came back. I also noticed that the Viewfinder was dark, and that the shutter would only release I removedf the battery, so the camera is going back.
03-22-2017 01:29 PM
Thanks for your reply, Waddizzle. I thought low level formatting was going to cure my problem also. Yesterday the camera worked fine shooting a long burst of about 400 JPEGs at 10 fps in my back yard, but locked up again later in the morning when I tried to do some birding. After more testing today, I was able to shoot a similar burst with no problem. I let the camera rest for 5-10 minutes and then all of the problems came back. I also noticed that the Viewfinder was dark, and that the shutter would only release I removed the battery, so the camera is going back.
