11-01-2014 10:21 PM
In Manual Mode on the 7D Mark II, with a hard ISO set, the exposure level indicator disappears from the bottom of the viewfinder. If you switch ISO to Auto, the exposure level indicator appears at the bottom of the viewfinder as expected.
Is there a reason that there is no exposure level indicator visible (except the vertical one on the right side) in Manual Mode when an ISO is set manually? This seems like it might be a glitch.
Thanks.
Bev
11-09-2014 04:56 PM
03-12-2019 03:30 AM
Well, I already bought EOS 7D M2, to upgrade from EOS7D. I heavily use the exposure meter in Manual mode. It was very convenient in 7D. Now, in M2, it is an inconvenience, because it is not clearly visible in Manual mode. It is an annoyance, and I am not happy about it.
03-12-2019 04:45 AM
I wrote to Canon via 'snail mail' and received a reply they would look into changing the firmware. That was over a year ago and after that intitial response there was no more communication. I have not used my 7D MII in over a year. I could have been a perfect camera but it is not.
I have had thoughts of posting about it on Facebook to get more exposure but I have not done that.
03-12-2019 11:24 AM
@mpddberry wrote:I wrote to Canon via 'snail mail' and received a reply they would look into changing the firmware. That was over a year ago and after that intitial response there was no more communication. I have not used my 7D MII in over a year. I could have been a perfect camera but it is not.
While it is always nice to have flexibility in customizing the camera's settings to fit the way you do things. I'm happy with the Pro layout of the 7D Mk II's exposure meter.
11-02-2014 02:05 PM - edited 11-02-2014 02:16 PM
I agree with you that the change is horrible. The indicator has completely disappeared on the top of the camera which makes no sense to me, either. I truly hope a firmware upgrade will get the indicator back wherre they were on the original 7D. This is almost a deal breaker, as I almost always shoot in Manual and use Spot Metering. Bad Bad Choice, Canon!
One good thing is that it is still available on the Quick menu, but that does not make up for the loss!!
11-02-2014 03:56 PM
So you've actually held a 7DMkII and made this determination? Or are you just repeating what others have said/written?
11-02-2014 06:57 PM
I have one in my hands right now! There is no indicator on the top of the camera in Manual and only a tiny indicator on the right hand side of the view finder. I called Canon to ask if this was a problem with my camera, but was told that it is one of the "quirks" of the camera. I seriously hope they change it.
11-02-2014 07:16 PM
They actually told you it was a "quirk"? That is some irresponsible customer service and very unlike Canon. I'm surprised and dismayed to hear that.
11-02-2014 07:41 PM
Irresponsible? Wow! A quirk isn't a negative. Not even close.
11-02-2014 08:20 PM
11-02-2014 10:13 PM
