09-03-2020 09:30 AM
I would like to ask, if is it possible to disable LCD auto turn off? Because I want to use this camera for streaming and every 30 min LCD display shut down. In the settings I see only the settings for auto turning off the whole camera.
Thank you
09-03-2020 10:50 AM
In the US, the EOS 250D is known as the EOS Rebel SL3. According to Canon it has clean HDMI output.
Your settings seem to be incorrect. I suggest that you download a copy of the full user manual.
09-04-2020 09:01 AM
Yes you are right - it has HDMI output. But the display turns off after 30 minutes regardless of whether the hdmi is plugged id or not. Unfortunately, nowhere in the settings I do not see an option to disable the automatic switching of the display during inactivity.
09-04-2020 09:19 AM
Are you recording on the camera or just using HDMI?
09-04-2020 09:31 AM
I am using camera with HDMI to streaming with OBS studio.
09-04-2020 10:13 AM
I was hoping that it was the 30 minute recording limit, but it appears not.
Are you sure the camera is not overheating and shutting down? Is it always *exactly* 30 minutes?
Have you tried it with just the LCD to see if you get warnings?
