11-22-2014 12:26 PM - edited 11-22-2014 12:55 PM
Recently purchased a new &d MKii. (yesterday) Using a Conon 100-400 lens and taking pictures high speed and continuous with the shutter release button and then looking at the in Lightroom all the pictures "grayed out" about 30% on the right side of the photo. How can this be. This is the 8th canon camera that I have owned and used. I have never seen this before.
Steve
11-30-2014 11:28 AM
From Canon:
Thank you for following up with us.
It is strange the way the right hand side of the image is grayed out. Does this issue happen often or just in this particular environment? Does the gray area stay consistent in the other images you referred to with the same issue?
If you have not already done so I recommend performing a couple of resets on the camera for further testing. Please follow the instructions below.
Power Reset
1. Make sure the camera is off, and then remove the battery, memory card, and lens.
2. Close the battery/memory card doors.
3. Turn the power switch to the "ON" position, and then press and hold down the shutter button for 10 seconds.
4. Release the shutter button, turn the power switch to the "OFF" position, reinsert the battery, memory card, and attach the lens.
5. Power the camera on.
Settings Reset
1. While the camera is on turn the mode dial to "P" which is the program mode which allows all menu options to become available then press the menu button.
2. Move across the top of the menu to the last wrench tab. (Yellow tabs)
3. Go down the menu list to "Clear Settings" and press the Set button.
4. Choose "Clear all Camera Settings", and press the set button.
5. To complete the reset highlight "OK" and press the Func./Set button again.
6. Next, move over to the Custom Functions menu list.
7. Reset the "Clear all Custom Func." settings as well.
We look forward to your reply with the information we have requested. Thank you for choosing Canon.
11-23-2014 02:18 PM - edited 11-23-2014 02:21 PM
Seems like something Canon has to fix.
Is it only in Lightroom? What if you look at the image on the camera screen?
11-23-2014 04:54 PM
11-23-2014 05:22 PM
Aperture priority.
11-23-2014 06:35 PM - edited 11-23-2014 06:35 PM
@PaulSoebekti wrote:
And can you post the exif information please?
Exif is in the image:
Manufacturer: | Canon |
Model: | Canon EOS 7D Mark II |
XResolution: | 72 |
Y Resolution: | 72 |
Resolution Unit: | Inch |
Software: | Adobe Photoshop Lightroom 5.7 (Windows) |
Date Modified: | 2014:11:21 18:39:36 |
MetaTools Info Offset: | 214 |
Exposure Time: | 1/500 s |
F Number: | f/5.6 |
Exposure Program: | Aperture-priority AE |
ISO Speed Ratings: | ISO 4000 |
Sensitivity Type: | 2 |
Recommended Exposure Index: | 4000 |
MetaTools Version: | 2.30 |
Date Created: | 2014:11:21 12:44:42 |
Date Digitized: | 2014:11:21 12:44:42 |
Shutter Speed: | 8.966 s |
Aperture Value: | 4.971 |
Exposure Bias: | 0 EV |
Max Aperture Value: | 5 |
Metering Mode: | Spot |
Flash: | Off, Did not fire |
Focal Length: | 400 mm |
Time Created Subsec: | 18 |
Time Digitized Subsec: | 18 |
Color Space: | sRGB |
Focal Plane X Resolution: | 6086.763 |
Focal Plane Y Resolution: | 6090.15 |
Focal Plane Resolution Unit: | Inch |
Custom Rendered: | Normal process |
Exposure Mode: | Auto exposure |
White Balance: | Auto white balance |
Scene Capture Type: | Standard |
Body Serial Number: | 032021004098 |
Lens Specification: | 100-400mm |
Lens Model: | EF100-400mm f/4.5-5.6L IS USM |
Lens Serial Number: | 0000000000 |
Compression Method: | JPEG (old-style) |
JPEG Interchange Format: | 874 |
JPEG Interchange Format Length: | 12454 |
11-23-2014 06:40 PM
11-23-2014 08:13 PM
Thanks. The original picture was RAW and converted to JPEG to email. The camera is being returned monday. I have a 5d MK III for a back up and sold my 7D on ebay-why-not a clue! Should have kept it.
11-24-2014 03:17 AM
Any chance of making one of the offending Raw files available?
11-24-2014 08:55 AM
You guys are overthinking this. The camera apparently has a shutter problem or a light leak. Trying to figure out which is a waste of effort. If the problem is repeatable, sending the camera back for inspection and/or replacement is obviously the correct course of action.
11-24-2014 10:18 AM
@RobertTheFat wrote:You guys are overthinking this. The camera apparently has a shutter problem or a light leak. Trying to figure out which is a waste of effort. If the problem is repeatable, sending the camera back for inspection and/or replacement is obviously the correct course of action.
And what do people who might subsequently have an interest in this thread learn from that attitude, Robert?
Time spent trouble-shooting and trying to understand an issue is never time wasted.
11-24-2014 10:32 AM
