11-02-2014 02:10 PM
Hi everyone, I am new here and if this question has been asked previously please point me to the post. I did browse through the previous questions but did not see this particular problem.
My probles lies with my 6D I shoot automobile racing with a 70-200 2.8 and a 580EXII flash, A couple weeks back during the night I was shooting manual mode and I noticed that my shutter speed kept changing on it's own, so I switched to TV mode and it worked fine for one week, but I noticed last night it started doing the same thing. I am setting my speed at 400 and repeatedly it would change to 200 or even lower, thus making my shots overexposed. Anyone have any ideas as to why this is happening??
11-11-2014 03:10 PM
@ebiggs1 wrote:Oh, yes, I do remember that. Yes it was the mode dial that kept switching. Man and it hasn't been all that long since I sold off all my xD cameras.
But it still can't accidentialy be changed on the 1 D series. Most controls require two buttons or dials.
Incidentally, I'd be surprised if the 7D2 doesn't have the same type of (locking) mode dial as the 5D3. Canon even offers an aftermarket modification to install a locking dial on the 7D. I never had it done to my 7D's because it costs $100, but there have been times when I've wished I had.
Truth be told, the locking dial is a bit awkward to use, since you have to keep one finger on the button while two others turn the dial. An old man's gnarled fingers can find that a bit of a chore. The shutter dial of at least one of my film Nikons had a better arrangement: you pulled up the rim of the dial and turned it to set the speed. Then when you let go, it snapped back down and couldn't be turned.
11-11-2014 04:15 PM
It is gone altogether on the 1D series. ![]()
06-28-2017 11:55 AM
I've been browsing about this issue and the answers so far couldn't help me. then i just played around with my setting which has been a while since i did it. And somehow i found the the solution for me..not sure it's the same issue for those seeking the answer though
Mine is solved by going to C.FnI : Exposure, then in menu no, 6 - Exposure Safety Shift. somehow it was set to 1. Enable (Tv/Av). not sure if it was the standard setting. But once i disable it, my shutter is not changing anymore when i use shutter priority
i've tested the Av mode, it still works as it used to (shutter changes according to the set apperture). and my problem solved now!!
