12-22-2013 05:32 PM
My 60D starts taking pictures when I put cable plug in the jack. Worked fine last time that I used it. The remote box isn't even plugged into the other end of the cable. Any ideas?
12-23-2013 03:18 PM
It sounds like your cable is shorted / bad.
I have the Canon version. I can tell you the camera side is a 2.5mm stereo headphone jack -- but not being sure which Vello remote you have (or being able to look at it) I don't know what the other side is. When I look at their wireless "airwave" remote it looks like it has the same jack on both sides.
In any case, it's a _very_ simply mechanism. There are three wires inside the cable and the "stereo headphone" style jack has 3 conductors on the post.
If the shutter button is pressed half-way then the middle and end farthest from the tip create a connection. If the button is pressed all the way, then all three create a connection (tip, middle, and base of the pin.)
If the camera stars triggering the shutter just becuase you plugged it in, then that means something is conducting across all pins -- and given that this doesn't happen unless the cable is connected, it almost certainly points to a short in the cable.
Replace the cable. You may have to contact Vello or a store that sells them. They do actually sell *just* the cable (without making you buy the whole remote to get one.) This is because you can buy extra cables for cameras that require different types of connectors.
12-23-2013 10:43 PM
Hello TCampbell: I went to a local camera store and got an inexxpensive wired shutter release. The camera works fine with it! So I tried the Vello control box with the new cable and it works OK also. The Vello is a wireless unit so I am back in business I believe. Thanks for the help. It does seem the Vello cable is bad.
