05-16-2022 04:42 PM
I purchased a used Canon 7D Mark ii. When I setup bracketing, there are 5 brackets, not the usual 3 brackets. How do I change this option to 3 brackets?
05-16-2022 04:58 PM
If you go into the Custom Settings tool (orange tabs) you can reset that.
But, I recommend you completely clear all camera settings and custom settings since there may be other settings you haven’t discovered yet.
05-16-2022 04:58 PM
05-16-2022 05:27 PM
Thanks for the assist. I found the custom setting to select # brackets. I had used 'Clear all camera settings' but it didn't reset Custom settings.
05-16-2022 05:29 PM
If your camera is like mine, clear custom settings is the last page of the orange tools.
