Would a 2x extender work with EOS RP and 70-200 2.8 EF?
DaleO
Will it work? I have an EOS RP, Canon 70-200 2.8 EF lens, which I use a converter to attach to the camera, would a 2x extender work?
I recall reading that the 2x extender didn't work with the EOS RP because the lens needed to extend into the camera's body, and there wasn't enough room with an adaptor, extender, and lens.
8 REPLIES 8
March411
Whiz
Whiz
From the Canon Website
Lens 1.4x   2x
RF 400mm F2.8L IS USM 560mm   800mm
RF 600mm F4L IS USM 840mm   1200mm
RF 600mm F11 IS STM 840mm   1200mm
RF 800mm F5.6L IS USM 1120mm   1600mm
RF 800mm F11 IS STM 1120mm   1600mm
RF 1200mm F8L IS USM 1680mm   2400mm
RF 70-200mm F2.8L IS USM Z 98mm-280mm   140mm-400mm
RF 100-300mm F2.8L IS USM 140mm-420mm   200mm - 600mm
RF 100-400mm f5.6-8 IS USM 140mm - 560mm   200mm - 800mm
RF 100-500mm F4.5 - 7.1L IS USM  420mm - 700mm   600mm- 1000mm
(Compatible with 300mm setting or longer only)
RF 200-800mm F6.3-9 IS USM 280 - 1120mm   400 - 1600mm
Marc
Windy City
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
jrhoffman75
EF lens mounts on the Canon EF-R lens adapter. Nothing extends into the R camera body. The Canon extender will mount on the lens and then mount on the adapter. The Canon extender has a “nose” that extends into the lens body. That is why the Canon extenders can only be used with canon L lenses. Image quality could take a hit; you can judge that.
That's what I read online. Since I'm shooting outside baseball, I'm unsure if that's a big issue, but I'm spoiled with the 2.8 lens.
Yes, I'm seeing 2.8L now. I was hoping for solution, but I have not seen one.
Nope, just read the spec as the name is misleading.
This lens is only compatible with fixed focal length L-series lenses 135mm and over, as well as the EF 70-200/2.8L, EF 70-200/2.8L IS, EF 70-200/4L, and EF 100-400/4.5-5.6L. Additionally, please see the lens and/or camera body manual for full compatibility information with the Extender EF 2X III.
I have both the EF70-200 f/2.8L II and the EF100-400 f/4.5-5.6L II. Also have the EF 1.4X III and EF 2.0 III. I get better results with the 1.4X and cropping.
Sorry, loaded the wrong table, here is the EF compatibility
EF extender compatibility guide
Lens Lens with 1.4× AF with 1.4× IS with 1.4× Lens with 2× AF with 2× IS with 2×
135 mm f/2L USM 190 mm f/2.8 Yes 270 mm f/4 Yes
180 mm f/3.5L Macro USM 252 mm f/5 Yes 360 mm f/7.1 No
200 mm f/1.8L USM 280 mm f/2.5 Yes 400 mm f/3.5 Yes
200 mm f/2.0L IS USM 280 mm f/2.8 Yes Yes 400 mm f/4 Yes Yes
200 mm f/2.8L II USM 280 mm f/4 Yes 400 mm f/5.6 Yes
300 mm f/2.8L USM 420 mm f/4 Yes 600 mm f/5.6 Yes
300 mm f/2.8L IS USM 420 mm f/4 Yes Yes 600 mm f/5.6 Yes Yes
300 mm f/2.8L II IS USM 420 mm f/4 Yes Yes 600 mm f/5.6 Yes Yes
300 mm f/4L USM 420 mm f/5.6 Yes 600 mm f/8 f/8 only
300 mm f/4L IS USM 420 mm f/5.6 Yes Yes 600 mm f/8 f/8 only f/8 only
400 mm f/2.8L USM 560 mm f/4 Yes 800 mm f/5.6 Yes
400 mm f/2.8L II USM 560 mm f/4 Yes 800 mm f/5.6 Yes
400 mm f/2.8L IS USM 560 mm f/4 Yes Yes 800 mm f/5.6 Yes Yes
400 mm f/4 IS DO USM 560 mm f/5.6 Yes Yes 800 mm f/8 f/8 only f/8 only
400 mm f/5.6L USM 560 mm f/8 f/8 only 800 mm f/11 No
500 mm f/4L IS USM 700 mm f/5.6 Yes Yes 1000 mm f/8 f/8 only f/8 only
500 mm f/4.5L USM 700 mm f/6.3 f/8 only 1000 mm f/9.0 No
600 mm f/4L USM 840 mm f/5.6 Yes 1200 mm f/8 f/8 only
600 mm f/4L IS USM 840 mm f/5.6 Yes Yes 1200 mm f/8 f/8 only f/8 only
800 mm f/5.6L IS USM 1120 mm f/8 f/8 only f/8 only 1600 mm f/11 No f/8 only
1200 mm f/5.6L USM 1680 mm f/8 f/8 only 2400 mm f/11 No
70–200 mm f/2.8L IS USM 98–280 mm f/4 Yes Yes 140–400 mm f/5.6 Yes Yes
70–200 mm f/2.8L IS II USM 98–280 mm f/4 Yes Yes 140–400 mm f/5.6 Yes Yes
70–200 mm f/2.8L USM 98–280 mm f/4 Yes 140–400 mm f/5.6 Yes
70–200 mm f/4L IS USM 98–280 mm f/5.6 Yes Yes 140–400 mm f/8 f/8 only f/8 only
70–200 mm f/4L USM 98–280 mm f/5.6 Yes 140–400 mm f/8 f/8 only
100–400 mm f/4.5–5.6L IS USM 140–560 mm f/6.3–8 f/8 only f/8 only 200–800 mm f/9–11 No f/8 only
100–400 mm f/4.5–5.6L IS II USM 140–560 mm f/6.3–8 f/8 only f/8 only 200–800 mm f/9–11 No f/8 only
200–400 mm f/4L IS USM  280–560 mm f/5.6 Yes [unsure] 400–800 mm f/8 f/8 only [unsure]
(without built-in extender 1.4×)
200–400 mm f/4L IS USM  400–800 mm f/8 f/8 only [unsure] 560–1120 mm f/11 No [unsure]
(with built-in extender 1.4×)
TS-E 17 mm f/4L 24 mm f/5.6 No 34 mm f/8 No
TS-E 24 mm f/3.5L 35 mm f/5.0 No 50 mm f/7.1 No
TS-E 24 mm f/3.5L II 35 mm f/5.0 No 50 mm f/7.1 No
TS-E 45 mm f/2.8 65 mm f/4.0 No 90 mm f/5.6 No
TS-E 90 mm f/2.8 125 mm f/4.0 No 180 mm f/5.6 No
https://eflens.com/lens_articles/ef_extender.html
Marc
Windy City
Personal Gallery
