RF 18-45mm lens won't extend/retract when camera is turned on/off
trev2
I have a EOS R100 with the RF 18-45 Lense.  The lense does not automatically extend and retract when the camera is turned off and on. Can anyone offer a solution for this, thank you.
9 REPLIES 9
deebatman316
That lens doesn't have a power retract or extend feature you must manually do it.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
Waddizzle
Which shooting mode are you using?
Does the lens work properly and refocus when you take photos?
I don’t use the R100.  I know that its bigger brothers have a setting that enables and disables the behavior.  It’s possible that your camera has this set to disable.
But first, we need to confirm the lens is working properly.
It doesn’t!?  I had assumed that it changed length as it refocused.
Well the retract feature is manually done on the zoom ring by turning it to just before 18mm. The lens doesn't have a Power Retract or extend feature at all. I even checked the manual for the lens and it shows how to manually retract the lens and extend it. It shows nothing about enabling power retract in the camera menu.
-Demetrius
Please start by verifying the following settings:
C.Fn 5: Retract lens on power off
Canon : Product Manual : EOS R100 : Custom Functions (C.Fn)
I believe its supported on the RF-S 18-45
This lens doesn't support power retract and extend you must manually do it. Power retract and extend only works on lenses with gear type STM mainly found in prime lenses such as the RF 35mm F/1.8 IS Macro STM lens. This lens uses lead screw type STM instead @Waddizzlehttps://gdlp01.c-wss.com/gds/4/0300044204/01/rfs18-45f45-63isstm-im-eng.pdf
-Demetrius
p4pictures
The lens has a "retracted" position and a "working position". You have to turn the zoom ring to go from retracted position to the working position. The retracted position is used to make the lens super short in length, and easier to keep on the camera or in a pocket when not taking photos.
This is the section from the lens instruction sheet.
Brian
Brian,
Agree.  My understating is the feature applies to the "working position".
normadel
Methinks the original poster wants his lens to do what point & shoots do...turn on camera and lens extends out, turn off camera and lens fully retracts.
Can the OP tell us more?
