08-31-2015 05:02 PM
Is there a write speed limitation on the 20D which limits the usable speed of compact flash cards? In other words, is there any reason to buy a new super fast cf card? And the same question applies for the 50D. I use a 50D as my main camera, but have a 20D as a backup. I shoot fast moving subjects in burst mode.
08-31-2015 06:43 PM
I don't have an exact answer because I am not familiar with when those cameras were released. Your question reminds of when people ask about putting the newer, higher octance gasolines into their older cars, way back during tghe octane war days between one gasoline brand and the next.. My answer had always been to point out that the car was designed to use the gasoline that was being produced at the time the car was produced.
Similarly, the best speed cards to use would be the ones that were on the market when the camera was released. Not the latest and greatest, but the cards that had been around during the design phase of the camera. I would conclude that you would not gain any advantage by using the latest, super fast SD card. Go with what works.
08-31-2015 07:55 PM
@JimP wrote:Is there a write speed limitation on the 20D which limits the usable speed of compact flash cards? In other words, is there any reason to buy a new super fast cf card? And the same question applies for the 50D. I use a 50D as my main camera, but have a 20D as a backup. I shoot fast moving subjects in burst mode.
The 50D's last firmware update made it compatible with the UDMA 7 standard. Meaning, yes it will benefit from the latest fastest cards.
Canon has released a firmware update for the EOS 50D.
Firmware Version 1.0.9 incorporates the following changes.
08-31-2015 11:23 PM
09-01-2015 01:22 AM - edited 09-01-2015 01:24 AM
Thank you very much, TTMartin. The updated 50D firmware has improved write speed capability. Mine was out of date. Your link was just what I needed.
09-01-2015 01:22 AM - edited 09-01-2015 01:23 AM
Thank you Peter, that helped.
09-01-2015 01:25 AM
09-01-2015 07:53 AM - edited 09-01-2015 07:54 AM
@JimP wrote:
Waddizzle, that was not useful at all. As it turns out 50D performance was upgradable, and by the way, neither of these cameras uses SD cards.
Well, his conclusion was correct. You wouldn't have gained anything by using the latest superfast SD cards.
09-01-2015 10:25 AM
@RobertTheFat wrote:
@JimP wrote:
Waddizzle, that was not useful at all. As it turns out 50D performance was upgradable, and by the way, neither of these cameras uses SD cards.Well, his conclusion was correct. You wouldn't have gained anything by using the latest superfast SD cards.
That is true! Just not much help. ![]()
