01-28-2025 10:53 AM
When trying to set a Destination Folder for image copy in EOS Utility to iCloud folder, I get the error "You do not have access permission for the folder. Please select a different folder."
The system folder path is "/Users/MyName/Library/Mobile Documents/com~apple~CloudDocs/Pictures/Canon" or "/iCloud/Pictures/Canon"
All other apps I use can create and access folders in iCloud, including macOS Image Capture.
I've tried the EOS Utility on macOS Sonoma and Sequoia (most recent versions) with same result. I checked the permissions of the EOS utility app, and they are the same as other apps.
Anyone else have success using the EOS Utility to write to iCloud Drive?
