01-11-2019 08:10 AM
I have a fault on my 1DX, if I put a card in slot two the camera will not switch on. I’ve tried every combination and different cards.. anyone had the same issue?
Thanks
01-11-2019 08:27 AM - edited 01-11-2019 08:28 AM
You likely have damaged pins in slot two that are being pushed together when a card is inserted and the camera won't power on to protect itself due to this fault.
CF and Cfast card sockets are a poor design for high insertion duty cycle operation because those pins are pretty fragile unlike the much more robust SD socket. For my 1DX and 1DX 2 they have a pair of large cards in both of them which has been sufficient to handle every single event where I use them and I then use the ethernet port to transfer images to the computer. I would not be at all comfortable frequently removing these cards,
Take a good look at the offending slot and see if you see one or more pins that are bent. If so it would be best to send it to Canon, other options are to live with one card slot or you can try to carefully straighten the pin yourself but I would want that connector replaced if there is a bent pin because once bent it will be easy to have it happen again. Or if you decide to straighten it and are sucessful then carefully insert a high capacity card in that slot and leave it there.
Rodger
01-11-2019 10:58 AM
01-11-2019 08:14 AM
Do you mean that it will power on with Card2 empty but not power on if you put a card in Card2?
Rodger
01-11-2019 10:22 AM
@jrhoffman75 wrote:Do you mean that it will power on with Card2 empty but not power on if you put a card in Card2?
Yes
01-11-2019 10:58 AM
01-11-2019 04:33 PM
John,
With your current 1 series, the standard RJ45 style ethernet connector is quite robust and is a safe way to do fast transfer as long as your PC also has a fast ethernet port. USB ports are designed as much for compactness as they are for robustness while the RJ45 style jack dates back to much earlier telephone days where reliability was a major concern.
It is possible to bend a wire in this stye of RJ connector but it isn't as likely and itis much easier to repair than the multiple tiny pin CF and Cfast sockets.
Rodger
01-11-2019 04:44 PM
Thanks Roger. I am going to try the Ethernet approach.
01-15-2019 01:52 PM
Yes, broken pin. One had managed to bend over and part snap so no chance of home repair. I’ll need a new card slot base. Thanks for your help
01-15-2019 02:08 PM
Canon service should be able to repair that quickly with no problem.
I know that CF and CFast cards are used in a lot of products but I think that connector setup is better suited for equipment where the card is intended to remain in place for long periods of time rather than where it will see a high duty cycle.
It probably varies by operating system and computer but with my HP Z820 for best results I had to manually set the etherhnet address in camera settings; when I set it up using the camera's connection wizard it worked fine but it would take a long time to connect every time I wanted to transfer photos. Once I manually set the address in the camera, enabling communications in the camera menu will launch EOS utility with it at the ready to start downloading photos screen in under 5 seconds. My PC has two gigabit Ethernet ports and I leave a cable in the second one just for connecting my 1DX and 1DX2 but I suspect you could use router ports with no problem.
Rodger
01-15-2019 06:01 PM
I have a 5D MarkIV and never take the CF card out. Just transfer to computer and then reformat. I was worried about the pins too. Had to send in a previous camara due to bent pins.
