04-09-2018 04:59 PM
I'm still running version 1.0.0. Has anyone uploaded the new firmware? From the details provided, it's improvements appear limited while the drawbacks appear constricting:
Fixes a phenomenon in which the camera may not function normally when images are simultaneously displayed
on the camera’s LCD monitor and an external monitor (via HDMI output).
1. Once the EOS-1D X Mark II is updated to Version 1.1.2 (or later), it cannot be restored to a previous firmware
version (Version 1.0.0 to 1.0.2).
2. Camera settings files created using a camera running Firmware Version 1.0.2 (or earlier) cannot be used on a
camera running Firmware Version 1.1.2 (or later).
3. Please use the latest EOS Utility version with the EOS-1D X Mark II after the camera has been updated to
Firmware Version 1.1.2 (or later). The latest version of EOS Utility can be downloaded from Canon’s Web site.
EOS Utility Version 3.5.00 or later support cameras running Firmware Version 1.1.2 (or later)
4. Accompanying functional improvements of Firmware Version 1.1.2 (or later), the instructional manual has
been revised. The latest version of the instruction manual can be downloaded from Canon’s Web site, so please
download the instruction manual together with the new firmware.
5. When using Version 4.7.10 (or earlier) of Digital Photo Professional to edit JPEG/RAW images captured with a
camera updated to Firmware Version 1.1.4 (or later), some of the Exif data may be deleted. In addition,
chromatic aberration correction, peripheral illumination correction, distortion correction, and Digital Lens
Optimizer cannot be used when processing RAW images captured using a TS-E lens (TS-E17mm F4L, TSE24mm
F3.5L II, TS-E50mm F2.8L Macro, TS-E90mm F2.8L Macro, or TS-E135mm F4L Macro). Please be
sure to update Digital Photo Professional to Version 4.7.20 (or later) before performing image processing.
Opinions?
04-10-2018 08:12 PM
@wq9nscwrote:AF micro-adjustment isn't part of the settings file because the primary idea behind these is you can move your preferred setup easily to other 1DX M2 cameras that you own and the micro adjustment fine tuning will vary by body.
Rodger
I have not checked for that, but it doesn’t make sense to me. What if I wanted to back up my camera’s settings? Losing all of my AFMA settings does not sound appealing. As far as transferring settings to a new body goes, clearing AFMA settings is easy to do.
04-10-2018 08:36 PM
I read the manual in depth and it appears AF microadjustment IS saved as one of the settings. So you can keep those settings safe on a card.
I put mine in a spreadsheet for future reference in case I need to re-enter the values.
Rodger
04-13-2018 04:20 PM
Thank you all for your help. It's much appreciated and has answered my questions.
Take care,
Mike in South Dakota
