11-27-2025 12:59 PM
This is most likely a rhetorical question. I was out with my RF 800mm f/11 lens and discovered that Electronic full-time MF doesn't work. And, according to the info page, that's true. I tried my RF 24-240mm and it didn't work either. Finally I found the page and tried the RF 100-500mm and it worked... so I wasn't going crazy. 🤪. Note that this is when the auto focus mode is set to servo. They both work when set to one-shot. (And the Electronic full-time MF is set to ON.)
The question is: why? I believe that it is not a physical issue -- since they both work in one-shot mode. I realize that the easy answer is the firmware just doesn't allow it but... bummer!!!!
This really is important when shooting small birds. The auto focus will get "stuck" on a near or far object such as a twig, leaf, or branch and not focus on the bird sometimes -- especially when the bird is in foliage. The easy cure for this is to rotate the focus ring a bit to get the focus off of that object.
I hope Canon will start enabling this feature on all of the lenses.
12-28-2025 08:32 PM
normadel,
Some cameras and some lenses support something called Manual electronic focus, or more commonly called, Lens Electronic MF.
Check your camera manual to see if your camera supports it.
With it, the user can override or fine tune your camera's AF by rotating your focus ring, even if you are in autofocus. It comes with a couple of other features like focus peaking.
I like it a lot.
Steve Thomas
