12-30-2022
04:15 PM
04:25 PM
Bought a new lens for my sons camera and didn't realize it needed an adapter, Which one do I need to connect to a EOS M50 and the EF-M 18-150mm lens? Thought this was the one but it's not.
I clearly know very little about cameras.
[Commercial link removed per forum guidelines and replaced with screenshot to facilitate discussion.]
12-30-2022 07:11 PM - edited 12-30-2022 07:13 PM
that lens is a RF-S 18-150mm and not the EF-M 18-150mm (two entirely different lenses). unfortunately, you cannot mount an RF-S lense onto a EF-M mount (there is no adapter available).
12-30-2022 04:55 PM
based on the info you provided, the EF-M 18-150mm should fit on the EOS M50 w/o any adapter.
12-30-2022 04:59 PM
Correct. The EOS M50 uses an EF-M mount so any EF-M lens can be directly connected; no adapter required.
12-30-2022 05:00 PM
You're putting an EF-M lens on an EF-M camera -- it should fit directly. No adapter is necessary or possible.
The adapter you've pictured is for fitting EF and EF-S lenses to EF-M cameras, like your M50. But the EF-M 18-150mm lens is -- as the name states -- EF-M, not EF or EF-S.
If you want to know more about fitting lenses to cameras, this guide might help: https://moonblink.info/MudLake/gear/lenses
12-30-2022 05:39 PM
I am at a loss. The lens doesn't fit. By looking at the photos can any of you see the difference? I see the difference and based on the lens and camera they should fit.
12-30-2022 08:19 PM
THANK YOU!!! Seems as though the lens I received was packaged incorrectly. Mystery solved..
Thanks everyone.
