12-29-2022 05:10 PM
I've got RF24-105 f4 L lens with R6. All's good and working as intended. However, I noticed when I customize control ring for exposure compensation, it's not working, all other options(ISO, Tv, Av etc) are working when I rotate the control ring except exposure compensation. Can anyone check if it's working for you and reply?
Thanks in advance,
Len
12-29-2022 09:30 PM
“ Update: I just tested Control ring set to Exposure compensation with all posible modes(Tv, Av, P and Fv) and it working. The same scenario doesn't work with M(manual mode). “.
Re-test Manual mode with ISO set to Auto. The camera must be able to control at least one leg of the Exposure Triangle for EC to function.
12-29-2022 05:50 PM
Do you need to half-press the shutter while turning it? Or, the [SET] button?
12-29-2022 07:09 PM - edited 12-29-2022 07:30 PM
In the menu of Castomize dials each have option with pressing Metering button or without(simple rotate lens Control ring). Every possible mode works with lens Control ring except Exposure compensation. Canon support guy said its related to lens/body communication and advised me to send lens for inspection. I just purchased lens and R6 camera.
12-29-2022 09:30 PM
03/02/2023: New Firmware Updates Are Available:
EOS R7 - Version 1.3.0EOS R10 - Version 1.3.02/07/2023: New product announcements!
