Using the EF 85mm 1:1.8, how to improve focus
Ramsden
Mentor
Hi folks
EOS90D currently with my EF 85mm 1:1.8 attached.
I've had my camera nearly 2.5 ys now and bought a few lenses early on, in a waive of enthusiasm.
Now I'm trying to work out what they all do!
The 85mm is, on the face of it, a decent lens for a day out. Not to heavy, and reasonable price.
But this week, having rediscovered my 24mm, I took the 85 for a walk along my Yorkshire footpaths and lanes. At first I thought I was doing something wrong, till I did some more research into the 85mm.
When I was trying to photograph a plant, for example, I could only get a small part in focus. But this is what the 85mm does, as it creates loads of bokeh.
Apparently if you try to take a portrait, sometimes, it  can only get one eye in focus.
Today I went back to get some pictures of Scotch Broom, which were beautiful yesterday. Of course today,  they were passed their best, but I hope the photograph makes my point.
So my question to my learned friends across the pond, is, have you used an 85mm, and how do you get the best out of it?
Thanks
Ramsden
Lee,
The EF 85 1.8 was my favorite lens when I shot film a few decades ago. Then getting back to photography
a few years ago with a Rebel T7, I picked up an EF 85 1.8 again and liked my results. Some of my favorite shots with it were of the Grand Canyon.
However it was poor at quasi macro shots. I thought it was good at head and shoulder shots and small groups but the EF 50mm f2.5 compact macro I had at the time was better in my opinion.
When I upgraded to a 90D body, it seemed harder to get better than average results with the 85 1.8 for some reason. When I got an EF-S60mm f2.8 macro (the 50mm macro bricked) I parted with the 85mm.
The 60mm macro like the 50mm macro produced (in my opinion) better results across the board for me than the 85 1.8 and it is an excellent macro lens as well.
I don’t know if it’s the higher MP sensor of the 90D vs the T7 or if it was my technique, but the 85 1.8 fell out of favor with me. I do miss the the way my out of focus backgrounds looked when I got a decent portrait shot with it at f1.8 or f2 but like I said, it seemed more difficult to do so for me with my 90D.
18 REPLIES 18
wq9nsc
To me, the two most underappreciated lens in the EF series are the EF 85 f1.8 and the EF 400 f5.6.  Both perform well beyond what their relatively low cost would imply.
I used my EF 85 f1.8 many years for basketball and indoor soccer and it is a very decent low light sports lens.  And the ability to create nice bokeh in other applications is a natural for it.
The most important advice I have when shooting wide open at short distance with this lens is to remember that you need to choose the best focal point to optimize desired depth of field under these conditions.  The area to the front of the focus point is shallower than the point beyond the focus point so consider using a focus point biased forward within the desired area of depth to provide the best result.
Also, if you have not already done the micro focus adjustment for this lens for your camera body I would do so because this is critical with shallow DoF setups.  It is easy to do and explained in Canon's micro focus online documentation but I use a slightly modified system because I have multiple camera bodies so I want to minimize calibration time when adding a new lens.
Instead of exactly following Canon's method, I mount the lens on the body and take 3 images at each of 7 micro focus offset points and then download the images to the PC to closely examine the results.  You want to use a single micro point in AF select, have plenty of light so that you can use high shutter speed, and of course shoot with the aperture wide open.  Although the micro focus adjustment holds over a wide variety of conditions, it approaches perfection for the conditions used for setup so in your case I would do fairly close spaced shots for your test.
I take 3 shots at calibration offset 0 then another 3 shots each at plus 1, 3, and 6 and then repeat at minus 1, 3, and 6.  Then dump the images to your laptop or desktop to examine in detail and you will either decide that one of these offsets is perfect or you can see where to interpolate between offsets to take a second series of test shots.  This is fast and easy and well worth the time spent.
Of course you can always step the aperture down to make things less critical but then you lose some of the capabilities of the lens and in my experience, a properly set up f1.8 is a pretty forgiving lens.  A couple of years ago I bought an EF 85 f1.2 which produces amazing results but I am always a little nervous using it for critical shots that can't easily be repeated because just a slight error with the tiny depth of field at f1.2 results in garbage.
Happy image capturing, that is a gorgeous plant and a beautiful image capture by you!  My daughter is headed to the University of Manchester in the fall for her PhD in applied math/epidemiology so I am looking forward to some photo trips to the UK.  I have been in England multiple times but it was always on business/consulting trips so I look forward to some relaxed sightseeing of the beautiful countryside.
Rodger
stevet1
Ramsden,
If my memory serves me right, if you are using the Canon EF 85mm f/1.8, that lens does not have image stabilization.
If that's the case, you'd probably be better served by using it on a tripod, where you'd be inclined to turn image stabilization off anyway.
Supposedly, Tamron was the first (and probably only) company to offer a stabilized 85mm f/1.8.
Steve Thomas
Hi Roger
Thanks so much for your detailed reply. I will do my best to make those changes.
But, I was so pleased to see that your daughter is coming to Manchester University. I'm a double alumni, 1st Degree and PhD. I worked there for three years as part of my research programme. In fact, they funded me to attend a couple of conferences in the USA. I think the first one was in Washington based on the Quality Management guru Dr W.E, Deming. I have sad recollections, because my friend and I went up the Twin Towers about a month before the hit.
Anyway, when you get to come to Manchester, let me know. I live about an hour away. Great city. She'll love it. I'm a very proud alumni.
Keep in touch
Ramsden
Hi Steve,
That's correct no IS. Its quite lively for an old guy!
But I'm also starting to use the Shoot menu to do some tricky shots alongside the river and woodlands. In fact I was giving it a go about an hour since.
Thanks for your help
Ramsden
 This was an interesting one (for me)as it was getting cloudy and not much light, so I ended up (over adjusting) the exposure compensation slide. I'm still getting used to all the features on the camera, as well as knowing what to do when things aren't right. Plus, I'd just watched a video on how to do it.
LeeP
Whiz
Whiz
I have the EF 85mm 1.8 that I bought because "everyone" says 85mm is so awesome and I truly hate it. It's not "tele" enough to be a telephoto and at the same time "too tele" to be a walk-around lens. The lens itself is truly wonderful and high quality, but it's the wrong focal length for me.
In the rare instances that I've used it, I've done head shots with it. Keep us up to speed on your discoveries as you dive in and develop your competence with this lens. I will look forward to learning from you.
Choose to speak positively to people; the world has enough unhappy bullies.
Please ask for an invite to my Knowledge Base articles for tips on teaching photography, composition, and non-compensated product reviews.
Hi Lee
Thanks for your comments. I guess that was a little bit of the thinking behind my original post. Its a strange beast to handle and I was all over the place this morning. But at the same I got some decent shots, with the obligatory bokeh. However, if you'd seen me wrestling with the branches, and then having to take 4 steps back to get focus, you'd have had a laugh!
Ramsden
Thank you Ramsden and I messaged you via this site.  And enjoy your EF-85 lens!
Rodger
Hi Rodger
Thanks, and since your post I appreciate more how and what the 85 has to offer. I noted that you used yours for indoor sports games. Here in the UK, some of us are big cricket fans, so yesterday I was watching my local team play. I set my aperture wide open, it was a grey day and I was about 70-80 metres from the players. I was on AI servo and H multi shot. There are two batsmen on the pitch, and a bowler runs up and bowls, either fast 80-90 mph an hour, or slower spin bowling. Its not great photography but I was very impressed how it captured clear shots of the bowler and the batsmen.
I continue to learn, and it will be with me on a lot of days out. Steam trains next.
Thanks
Ramsden
First a batter.
 Bowler releasing the bowl, as the none strike batter is setting off to run.
