04-11-2024
09:55 AM
02:08 PM
A friend of mine was lucky enough to have received her Canon RF 200-800mm lens that she had ordered in Nov. 2023. She has encountered an issue with the lens design. The new lens does not appear to allow use of a filter while the lens hood is in place. She and her camera shop have tried a number of different brands of filters, but none appear to allow the lens hood to be mounted while a filter is attached. This seems to be a rather inexcusable design flaw on Canon's part. When Canon technical support was contacted, no one appeared to know anything about the issue. With the exception of this problem, she loves her new lens. Has anyone else encountered this issue with this lens?
07-07-2024 10:52 PM
I got my 200-800 five months ago and have had no issue with my filter, which is a B+W protect filter - used to keep environmental materials, such as dust, sand and salt off the expensive front element of the lens.
If you get a good lens, never put a cheap filter on - it basically degrades the image and the investment one has just made. Prograde filters are anything but...
07-07-2024 11:24 PM
Thanks so much for figuring out the cause of the problem for my friend. As I mentioned previously, when my wife's RF 200-800 lens arrived, we had no problems with the hood while using B+W or Canon filters. These were the only 2 brands I had on hand. I have confirmed that my friend had a Promaster filter, but still do not know what other filters were tried at her Canon dealer. Perhaps they were also cheap filters.
07-08-2024 12:22 AM
This was a cumulative effort and culmination of a great many minds. I am fortunate and grateful to be amongst you. 😍
07-08-2024 05:28 AM
Rick you are as gracious as you are knowledgeable, and in both you excel.
11-04-2024 03:53 PM
I've just purchased this lens and have the same problem. The filter I tried was a Sigma 95mm.
11-04-2024 04:35 PM
With our lens, I have tried filters from B+W and Canon. Both of these brands worked just fine. My friend eventually purchased the Canon 95mm Protector Filter and that worked just fine for her.
11-04-2024 04:46 PM
Thanks, I'll head to my local dealers tomorrow!
11-04-2024 08:05 PM
My lens just arrived. I don't have the filter yet but mine is 95mm and has a 3.3 mm frame.
The filter wasn't expensive and it's the first KF Concepts filter I've tried. I bought the higher end model that has 99.8 light transmission and a titanium coating If I have any problems with it, I'm just going to buy the Hoya EVO. This is the one that lensrentals rents the lens with and I've owned many Hoya filters since the late 70's.
05-02-2025 05:46 PM
I have that problem and it seems others do as well. The hood supplied by Canon with the lens, physically cannot be put back on when a filter is installed. I was at the camera shop today and they could not figure out how to solve the issue.
05-02-2025 05:49 PM
which filter did your friend get to successfully fit and permit the lens hood to be installed? I am currently having that problem. The camera store only had the Promaster UV filter and the outside diameter would not let the hood be installed.
