Loose part inside EF 24-70mm F2.8L II USM
golf4motion
Hi, can you tell me from what part of the lens Canon EF 24-70mm F2.8L II USM is this plastic part? I find it between the rear glass and aperture unit.
6 REPLIES 6
kvbarkley
Looks like an eccentric bushing used for adjustments.
You might be able to look through the pictures here and find it:
https://www.lensrentals.com/blog/2013/01/24-70mm-f2-8-lens-teardown-comparison/
golf4motion
I find from where is this small part. Its on rear glass part
jrhoffman75
Check your Private Messages.
Good info but it says nothing about this small part. Do you know what is this part used for?13554.jpg
kvbarkley
I told you, it is an eccentric adjustment, used to make small changes in alignment that are then locked down.
Thanks!
