09-03-2024 05:07 AM
Hi all,
I have a EF-S 17-55 f/2.8 IS USM Lens I bought second hand about 12 years ago. It had an issue at the time so I replaced the ribbon cable and it's been fine until recently.
It seems that I should have used loctite on the screws because the one securing the barrel/zoom ring tab has come loose. It's the part that grips the inner barrel to the outer zoom ring. I couldn't find it inside the lens so it seems to be lost. It's about 1.66mm in diameter (including threads) and 2.46mm long (including the head).
Could anyone assist with a part # or source where I can purchase said screw?
Thanks,
09-03-2024 09:40 AM
Loctite or a drop of any two part epoxy will work. Good luck on finding the screw as some products have odd specifications for them.
09-04-2024 03:59 AM
I've taken some more measurements of the thread and I'm fairly sure it's a L2.5mm M1.7x0.35mm so I'm going to try to find a generic countersunk replacement.
I can only find 3mm screws though so if that proves too long I might have to try to grind it down.
09-04-2024 05:54 AM
You could try US Camera-dot-com.
