04-23-2024 09:25 PM
Hey,
Recently I’ve noticed my R6 Mark II sounds like something is loose inside. I’ve attached the video to this message. Does anyone else have this issue?
Also, every now and then the camera will shoot a very highly exposed image then the next image will be the correct images settings. This could possibly be the result of the loose equipment inside.
04-23-2024 09:37 PM
Chances are (high probability) this is the IBIS mechanism.
If it rattles when off, and doesn't rattle when on then it's likely the IBIS. Nothing to worry about 🙂
The exposure issue might be related to your settings, or maybe the lens. Are you using Canon lenses? Of so, try resetting the cameras settings to defaults and retest. After doing this if you are still experiencing abnormal behavior, we'd be happy to look into the issue further. 🙂
