Image circle of the TS-E 50 mm lens
unclejace54
Enthusiast
Hello folks. I am using the TS-E 50mm lens with a medium format camera and sensor that is larger than full frame, 33x44mm. I see that Canon has specs for image circle for the TS-E 24mm (67.2mm) but I cannot find any information on image circle size for the 50mm. I have seen some specs from forum and review sites but nothing that hints it comes from the manufacturer.
Thank you for your help.
John_Q
Hello unclejace54. I was able to find that spec on the Canon Hong Kong site. The image circle for the TS-E 50mm F/2.8L Macro lens is 67.2mm.
3 REPLIES 3
John_Q
unclejace54
Enthusiast
Thank you.
I may have jumped the gun on accepting your solution. I went to Canon Hong Kong and can't find where you found that info. Could you send me the link? FYI, the 24mm TS-E has an image circle of 67.2mm. It's the same for the 50mm?
