11-19-2012 11:14 AM
Hi there everyone. My question is that I want to know about a lenses that supports me good definition and quality in low light conditions. I am recording with a Rebel t3i. Thanks in advance.
11-19-2012 03:51 PM
So we know what how technical of a discussion to have, can you give us a bit more information about what your experience is with photography / videos, what lens(es) you have now, what you are filming, etc?
11-19-2012 11:41 PM
This is my first DSLR and I am recording weddings and parties. For the nature of these events, most of them have low light conditions. I also need advice of a gadget to record everything without changing SD cards. Thanks.
11-20-2012 12:11 AM
@bebefle_89 wrote:This is my first DSLR and I am recording weddings and parties. For the nature of these events, most of them have low light conditions. I also need advice of a gadget to record everything without changing SD cards. Thanks.
The solution is a bigger (higher capacity) SD card. 😃 They go up to 64gb and 128gb now which should provide A LOT of recording capacity.
@bebefle_89 wrote:At the time, I've been working just with the 18-55 (the one that comes with the camera package), but I need an aditional lense because this lense I have, is graining all my videos because of the adjustment of ISO.
How much do you understand about f-stops, shutter speed, and ISO? What exposure settings are you using now for your videos? In short, you need a lens that can open up to a larger aperture (such as f/1.8, f1.4 or f1.2).
Here are some guides that will be helpful in explaining these concepts for you:
http://www.exposureguide.com/exposure.htm
http://www.makethephoto.com/articles/how-to-make-the-jump-from-automatic-shooting-to-manual-shooting
11-20-2012 04:27 PM
Hi JFO ...I understand about f stops, that is not the problem. The problem in here is what lense you recommend, I want a 50mm f1.4 or f1.8...and there is a lot of differece in price between them, is there much difference in image quality? which one would you buy? is there any other lense you recommend? Thanks
11-20-2012 06:26 PM
I would go with the f/1.4
11-20-2012 07:40 PM
@bebefle_89 wrote:want a 50mm f1.4 or f1.8...is there much difference in image quality? which one would you buy? is there any other lense you recommend? Thanks
I wish you would have just said so earlier! 😃
@David wrote:I would go with the f/1.4
I agree. If you can afford it, it has a wider aperture, better focus performance, and prettier bokeh.
11-20-2012 09:00 PM
Thanks both 😃
11-19-2012 11:44 PM
