Excessive Chromatic Aberration in Canon EF 50mm f/1.2 L USM - Is This Normal?
marrasander
Hello Canon Community,
I recently purchased a Canon EF 50mm f/1.2 L USM lens and have been noticing a significant amount of chromatic aberration in my photos. This occurs even in well-lit conditions and is particularly evident around high-contrast edges.
I am attaching a raw, unedited snapshot that I took with this lens to illustrate the issue. I would greatly appreciate it if anyone could take a look and let me know if this level of chromatic aberration is normal for this lens model, or if it is possible that my lens is defective.
Thank you in advance for your help!
Best regards,
Sander
18 REPLIES 18
kvbarkley
Ken Rockwell says there is some, but this seems excessive.
https://www.kenrockwell.com/canon/lenses/50mm-f12-continued.htm
Waddizzle
What camera body?
Are you using any filters?
Can it be removed by applying lens correction?
Has the posted image been cropped from its original size?
Agree with kvbarkley.  The CA on the edge of the sleeve and tie does seem excessive.  Have you run the image through DPP?  Do you have a lens profile downloaded?
“ I am attaching a raw, unedited snapshot that I took with this lens to illustrate the issue. “
The posted image seems to have been edited or modified in some way.  It doesn’t contain EXIF data and it has a resolution of 999 x 771 pixels
ebiggs1
Well I don't have to rely on Ken Rockwell or any bodies guesses since I own this lens and have for years. I can tell you mine has virtually no CA. While it may not be the sharpest 50mil on the market it has plenty of IQ
Some samples I just shot, just for you. The last one is an extreme blow up. The middle one shot at f1.2.
EOS 1DX and many lenses.
ebiggs1
ebiggs1
However the fix is simple with Photoshop. But you sample has more issues than just CA.
Peter
Looks like my EF 50/1.2L USM. Axial chromatic aberration. Worst at f/1.2.
Camera is a Canon EOS R5.
No filters used.
I try to remove it in LrC with Lens Correction Color, but that's a pain and often creates lots of artefacts by removing magenta/orange/green color in places I don't want to be removed.
Yes, the image I posted is just a screenshot of a portion of the photo in 100% zoom. I just wanted to illustrate the issue. I just wanted to know if this much CA is normal for a Pro lens like the 50mm f/1.2 L USM.
