EF-S 10-22mm Canon not working in AF correct
AlanRhodes
My EF-S 10-22mm Canon lens in AF mode is mostly taking out of focus pictures. I tried the basic clean the post but still keeps center of image out of focus. All my other AF lens work fine. Base is a Canon 60D. I have had lens new for about 5 years with no issues until now.
Any suggestions?
@AlanRhodes wrote:
Thank you all. I am going to send in the EF-S 10-22 to Canon and hope the cost is not too high to repair an already costly lens. I am buying a Tamron AF 17-50 mm F/2.8 SP XR Di II VC to have for this weekend sons grad party since my go to  Canon lens for this type of family shots is out of serveice.
Feeling a little burned on the Canon lens, I paided the higher lens cost for the Canon expecting longer service and quality then I received. But since I am a novice I am going to give Tamron a try for my future business this go around.
Regarding the Tamron lens, the non-VC version is thought by most users to give better image quality than the more expensive VC version. And both versions do not have a USD focus system, which Tamron is starting to put on their more premium models and is similar to Canon's USM. So do not expect the same level of focus performance as you would typically see with a 10-22mm or the Canon EF-S 17-55mm, which costs more but also gives top quality IS and a slightly longer telephoto.
Frankly, the problem you have with the 10-22mm seems quite unusual. Not to defend Canon (they can do that themselves), but I rarely see any complaints about that particular lens. Most users are very happy with the 10-22mm, many consider it one of the best ultrawides made by anyone, and decentered lens elements are usually the result of a hard bump to the lens or heavy wear and tear on moving parts, or occasionally a manufacturing flaw. I would encourage you to not judge Canon lenses on the whole, or even this ultrawide model, based upon your bad experiences with this one particular copy of the lens.
For your purposes - family shots - an ultrawide lens wouldn't be my first choice anyway. I think most photogs would call a 17-50 or 17-55/2.8 a better choice. Taking photos of people with an ultrawide, they often end up too small in the image, or heavily distorted if the lens is used close enough to fill the frame. This isn't any fault with the ultrawide lens, it's just the nature of wide angle optics. There are reasons that portrait lenses tend to be short to moderate telephoto focal lengths. A standard zoom (covering slightly wide to normal to short telephoto range of focal lengths), such as 18-55, 17-50, 17-55 would be a better choice in most cases.
I'm sure ebiggs assertions about EF-S lenses have a lot to do with his use of several cameras that cannot be fitted with EF-S lenses. I do too... so I minimize the number of "crop only" lenses in my kit (but the EF-S 10-22mm is one of several exceptons). You don't have this limitation with a 60D, which can use both EF and EF-S mount lenses without any problem. That being the case, the EF-S 17-55/2.8 IS USM is likely a better choice for you. For close to the same money, it has better image quality than the 17-40L, as well as f2.8 aperture and a wider range of focal lengths. The only place the L lens excels over the 17-55mm is probably build quality... The 17-40L is likely a bit better built and sealed to resist dust and moisture.
There are not and never will be an EF-S L-series lens. This isn't in any way due to the quality of EF-S lenses. It is only because Canon's own definition of what constitutes and L-series includes a stipulation that they must be compatible with all EOS cameras past, present and future. By design, EF-S lenses are not usable on film, digital full frame, or digital APS-H crop sensor camera models. They are compatible with APS-C crop sensor models, which are the vast majority of DSLRs that Canon sells, beginning with the original digital Rebel and 20D models of 2004/2005.
Several EF-S lenses are top quality and offer performance that rivals or even sets the standard among all manufacturers. The 10-22mm is one of those (usually... a faulty copy such as yours is very rare). I'd also count the EF-S 17-55mm, EF-S 15-85mm and EF-S 60/2.8 Macro lenses among the very best in their respective categories.
Alan Myers
San Jose, Calif., USA
FLICKR & PRINTROOM
21 REPLIES 21
ebiggs1
You cleaned the contacts on the lens and the camera with denatured alcohol and a q-tip?  You did not try to use an eraser didi you?
Hello, Thank you for response.
I had cleaned with denatured alcohol and q-tip just now but same issue. 1st I only cleaned with lens cloth. The red dots always pick to focus on right side of image and never on center subject that only recent started. Other AF lens work fine.
"Other AF lens work fine."
OK now you need to try your 10-22mm on another camera.  If it still misbehaves, call Canon Support for a local repair shop.
My son brought over his Canon and the lens worked better on his base then mine. Any help on what looks like my base EOS 60D? Strange as my AF telephoto works fine on base but the 10-22mm seems to focus on subjects more on the right on my base but center correctly on my sons canon base. The red dots always light up on objects on right on mine.
Help please, thank you
On the floor of the mirror chamber (just below the mirror) are all the AF sensors. I'm wondering if perhaps you've got something blocking that center AF point.
Tim Campbell
5D III, 5D IV, 60Da
Thank you, just checked and they all look good and I have cleaned them all
"My son brought over his Canon and the lens worked better..."
What does "better" mean?  Either it worked or it didn't.  If it is still screwed up, even a little, there is something wrong with the lens.  If it worked it is your camera.
Yes did not work on both. I just took some more test image and can see right side of image is clear and all from center to right is not focused in a landscape image below
in image you can see difference in stones and two birds
