Canon EOSM50 On/Off button- flashing green problems
Otiscat
The On/Off button on the EOSM50 is flashing inconsistently. The light stays off when in the Off position but when turned On it flashes and then stops working. For the past four years, the camera has been fine, without any problems. I replaced the memory card and Canon battery (tried 4xs) and the green list is still malfunctioning. Someone thinks it is a power circuit failure and needs to be replaced. Any idea as to how much this will cost to be repaired? Thanks!
1 REPLY 1
NatalyaP
Greetings Otiscat,
Per review, our facility currently charges a flat rate of $229 prior to any applicable taxes and prior to return shipping charges to repair the camera. I would recommend starting the repair process by visiting our online repair portal.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
Friends and Family
