EF 24-70mm f/2.8L USM Causing "Error 01" Message
rosenphoto
So, this is crazy and driving me nuts. I hope someone has an answer for me.
I'm a wedding photographer.
I have a 5D Mark IV and a 6D Mark II and a range of lenses.
A month ago, mid wedding, I start to get error 1 messages with my 24-70 2.8L lens. This is series 1 lens. Got that message on both camera, so assumed it was the lens.
That lens is my workhorse, so I tried to get it repaired. Was told it would cost me $500 and take over a month, so I'd have to rent a lens for that time, which would have run $300, so $800 all together.
Decided to buy a used lens for $750 instead.
After a week, that lens also started showing error 1 messages on both my cameras.
So, returned that lens and got another used lens and as soon as I put it on the camera, got another error 1.
So now I've gotten error 1 messages with three 24-70 2.8L lenses on both of my cameras. All my other lenses work perfectly on both cameras. Just the 24-70 2.8 L is giving me the error.
So it doesn't seem to be the cameras, it seems to be this series of lens.
Tried updating the firmware on both cameras, all of a sudden the original lens starts working. But then, after 100 pics or so, it goes back to error 1 again.
I have four weddings in December, I need to depend on my equipment, but I'm scared to use this lens, and this is my primary lens. I use it for 80% of my images.
Can't afford $2000 for a new lens. At my wits end here. Is it possible for a series of lenses to become incompatible with all my cameras? That seems improbable?
What's going on?
I don't know what to do. Can anyone help?
14 REPLIES 14
wq9nsc
This lens series has a design/build issue with an internal cable and when it fails the lens will generally only work at wide open aperture and this is generating the error message.  Canon repair is about the only solution, a lot of used 24-70 glass for sale is because someone is dumping their own problematic lens.
Rodger
I'm assuming this is not a repairable issue. So new lens is my only option.
I don't think Canon repairs this lens anymore. Too old.
I would jump right on this today...  Cyber Monday
Shop Canon Refurbished EF 24-70mm f/2.8L II USM | Canon U.S.A, Inc.
normadel
Does Canon refurbishing actually correct the design/build issue spoken of here and in numerous other threads? Or is a faulty cable just replaced with another of the same?
This may be a good solution. Was looking at the Sigma lens with same specs, and it's $1200. Do you know if refurbished Canon come with a warranty?
Gwiginton
What did you end up doing I’m desperate at this point myself but have a baby on the way and can’t shell out money for nothing
procameraman
Hi Danny
My Canon 24-70 2.8 L USM lens had the same problem, Error 1 and the diaphragm wasn't working.
I contacted Canon repair but they told me it is out of service.
I shipped it to Camera Repair Center in Glendale California and they replaced the power diaphragm ribbon cable and charged me $162.00.
BigLannie7
I was given a Canon EF 24-70 2.8 Lens to use on my new Canon EOS Rebel T7
It only works on 2.8 and any other aperture it gives me an Error 01, it also shows very dark in the viewfinder and has a black circle in the center of the viewfinder as well. Is the lens broken or am I doing something wrong?
Holiday
