01-22-2022 07:52 PM
Canon states they are colored this way to keep the flourite based elements from overheating in hot environments. So does this mean they perform better than Nikon, Sigma, et. al.? Or have the other vendors solved this "issue?" NASA even uses Nikon!!
01-22-2022 11:29 PM
Sony has some white lenses.
Nikon was probably the lowest bidder.
Originally, Nasa used Hasselblad.
01-23-2022 09:57 AM
This was apparently Nikon's position back in the NASA days (based on Google search).
01-23-2022 12:08 PM
"So does this mean they perform better than Nikon, Sigma, et. al.?"
Yes it does!
Otherwise it would be stupid to spend thousands of dollars of my money on Canon brand lenses. I, and you, are free to buy whatever. Canon has the best lens lineup in the world. Not even close.
01-23-2022 12:12 PM - edited 01-23-2022 12:12 PM
"This was apparently Nikon's position back in the NASA days..."
NASA is the last place I would go for a reason for or against. They screw up almost everything they do. Hubble come to mind right off?
01-23-2022 12:18 PM
NASA did not grind that glass......Perkin-Elmer did. And they trustedthe subcontractor to do it correctly. Lets see how Webb performs.
01-23-2022 03:07 PM
For the nitty gritty, read The Perfectionists by Simon Winchester.
01-23-2022 03:50 PM
"NASA did not grind that glass......Perkin-Elmer did. And they trustedthe subcontractor to do it correctly."
That's a cop out and not an excuse for sending a billions, that's billions with a b, of dollars gadget into space. And not their only screw up.
"Lets see how Webb performs."
I can image they will scrutinize it with a fine, very fine, tooth comb many upon many times. But it's NASA so who knows.
01-23-2022 05:25 PM
....and NASA fixed...rather elegantly I might add.. AND added more instrumentation to boot. Regardless, it would be niceto have the option to order a lens with a black body...as I suspect most photographers will not be working in those extreme "milspec" environments.
03-07-2022 09:50 PM - edited 03-07-2022 09:52 PM
My understanding is that as well as the coatings issue directly, a significant factor is that the white lenses are all metal, and in extremes of temperature they can expand/contract and thus impact the optics of the lens. This makes them extremely robust, but heavy. By making them white to reduce heat absorption and thus reduce expansion and contraction. Sony also make some metal lenses I believe, so I guess they are doing the same thing. Nikon have gone for engineered plastics that are less inclined to this thermal variation, so they don't need the white.
