Canon EF 100-400mm F4.5-5.6L IS II USM Lens vs Canon EF 70-200mm f 2.8L IS II USM
ilzho
Rising Star
Ok, I need some help from you all.
The price difference on the above lenses, is not that much, so my question is, which one would you get for sports/wildlife photography?
I was originally leaning towards  Canon EF 70-200mm f 2.8L IS II USM, but for a little bit more money I can get a lot more focal length.
I thought you guys could give me some helpful info......
Thank you,
David
23 REPLIES 23
TTMartin
Thank you,
David
I would go with the EF 70-200 f/2.8L IS II.
Add an Extender EF 2X and you've got a 140-400 f/5.6 lens. The image quality of the EF 70-200 f/2.8L IS II with the teleconverter is somewhere between the old EF 100-400 L IS and the new EF 100-400 L IS II. Which is stlll very good.
So you can make the EF 70-200 f/2.8L IS II longer, there is nothing you can do to the EF 100-400 L IS II, to give you a wide f/2.8 aperture.
Good point... Thank you.
This question gets asked from time to time on aviation based forums & from the info I have absorbed from reading the threads the 100-400 ends up the right (or better) choice for air shows. 2X teleconverters slow the AF so I think it's important to define how the lens will be used. A slower AF will hamper using it for fast paced action.
Want to use it mainly for horse racing, they rarely get over 40 mph.
I will use it for wildlife as well and other equine shots......
jrhoffman75
You need to determine how often you will be wanting greater than 200mm.
Once you exceed 200mm both lenses are basically f/5.6 lenses (not sure exactly when the 100-400 transitions).
Once you exceed 200mm the 100-400 will be sharper and faster focusing.
Do you have a good lens that will fill the 70-100 gap (or don't see a need to fill that gap).
In other words, do you want a 100-400mm f/5.6 lens or do you want a 70-200mm f/2.8 lens that can sometimes be a 400mm f/5.6 lens?
Do either of these fit the length restriction? What about the 70-300 L IS which is a very good lens in both sharpness & IS.
For sports and wildlife, you're better off with the 100-400mm f/5.6L II.
Diverhank's photos on Flickr
Both lenses are nearly identical in size.  I love the size of the 100-400.  It's highly totable, compared to a 150-600mm.
I am forced to agree with this conclusion.  At the short end its 70mm versus 100mm, which isn't much on a full frame camera.  On an APS-C camera, both lenses are kind of longish on the short end, and almost equally so.
At the long end, the 100-400 is giving you double the reach, but not the f/2.8 speed.  For outdoor sports, that is not going to make a huge difference because many outdoor sports have lights.  It will make a difference indoors, though.
