06-14-2016 08:09 AM
Ok, I need some help from you all.
The price difference on the above lenses, is not that much, so my question is, which one would you get for sports/wildlife photography?
I was originally leaning towards Canon EF 70-200mm f 2.8L IS II USM, but for a little bit more money I can get a lot more focal length.
I thought you guys could give me some helpful info......
Thank you,
David
06-14-2016 12:16 PM
Do either of these fit the length restriction? What about the 70-300 L IS which is a very good lens in both sharpness & IS.
06-14-2016 01:16 PM
@cicopo wrote:Do either of these fit the length restriction? What about the 70-300 L IS which is a very good lens in both sharpness & IS.
Both lenses are nearly identical in size. I love the size of the 100-400. It's highly totable, compared to a 150-600mm.
06-15-2016 10:39 AM
To me the question you asked is should I buy the best lens in the world or another lens that isn't. So you have my answer.
Of course the correct answer is to get the Canon EF 70-200mm f/2.8L IS II USM Lens. I don't recommend the 2x tele converter for any lens but the 1.4x does works fairly well on the EF 70-200mm f/2.8L IS II USM Lens. But.............
The beauty of a DSLR is the ability to use different lenses. The EF 70-200mm f/2.8L IS II USM Lens should not be the last lens you will be getting. So the best solution is the EF 70-200mm f/2.8L IS II USM Lens and later on one of the 150-600mm zooms on the market. No matter what you say about the 100-400 it doesn't have 600mm. And for wildlife photography 400mm is about the minimum focal length. 600mm is where it gets really good.
06-15-2016 10:46 AM
"For sports and wildlife, you're better off with the 100-400mm f/5.6L II."
Unless it is indoor sports.
