Best way to use a polaroid lens?
Tintype_18
I has taken some photos at a fish hatchery for a news article. However, I was disappointed that I still got some glare on the photos. The day was cloudy and set the camera accordingly. Will post a photo. IMG_9288.JPGCanon T7, 1/640, f/4.5, 32mm, ISO 1600. Suggestions and tips are welcome. Thanks.
John
11 REPLIES 11
rs-eos
Did you mean to say "polarizer" instead of "polaroid"?  Anyhow, a polarizer (e.g. CP) can definitely help reduce glare and reflections on the surfaces of water.
Ricky
jrhoffman75
Polarizers work best when the sun is perpendicular to the camera. They also tend to be less effective with wide angle lenses because the angle between the rays from the sun and the incoming rays to the lens deviate far from perpendicular.
Did you rotate the filter to see where the position of least glare was?
Tintype_18
Polarizer is the correct term. Polaroid is in the attic.
John, the filter I have screws into the lens but could be turned and locked with the ring. Will try it. Just thought, the lens used is an EFS 18-55mm. It's marked Macro 0.25m/0.8ft. That might be the problem. My other lens is the 75-300mm. Might try it. The wife has an SX530 HS but no filters for it. kvb, will look at the link. BTW, no fishing allowed.😉 Thanks to all.
Regarding the link: I recall using two polarized lenses and turning them until they turn "black" with nothing passing through.
John
A polarizer filter consists of two pieces. When you hold the one that threads into the lens and rotate the other you change the degree of polarization. In use the "outer" piece would be rotated till the reflection/glare is at a minimum. It can also be used to intensify colors in landscapes by reducing reflection from leaves, etc.
Hmmm. Camera is downstairs. Will be visiting the hatchery again tomorrow. Will see how it goes. Thanks, John.
John
Tintype_18
Took some photos with and without the polarizer filter. Difference of day and night. I was careful to see the morning sun to get the proper angle as suggested.
John
amfoto1
Be sure you are using a circular polarizer (C-Pol or CPL). Most sold these days are, so it's probably what you've got.
But there are also linear polarizers (Pol or PL). Those will interfere with autofocus and, in some cases, with metering. Circular polarizers do not interfere with either.
Not all C-Pols are created equal. "Cheap" polarizers can cause problems... soft images, ugly color tints. It's also best if any filter is multi-coated. This prevents problems with flare.
I recommend B+W circular polarizing filters as a good value (B&H Photo and Adorama sell them at very reasonable prices.). All B+W filters use top quality glass and their "F-Pro" and "XS-Pro" are multi-coated. The F-Pro have 8-layer multi-coatings (fine optically), while the XS-Pro have 16-layer "Nano" multi-coating that are a bit more durable, oil and water resistant, and a little easier to clean. While all B+W filters have slim frames (to reduce concerns about vignetting on wide angle lenses), the XS-Pro are slimmer than most. Probably not necessary if the widest lens you use is 18mm.
Both the F-Pro an XS-Pro are now "High Transmissive", too. This means they aren't as dark gray as "standard" C-Pol filters... so you lose less light to the filter. Standard C-Pol will reduce light passing through by approx. 1.25 to 2.25 stops. The High Transmissive type reduce it by approx. .75 to 1.5 stops. This can be important when shooting in low light conditions, so you don't need to use too slow a shutter speed or too high an ISO.
It's not uncommon for comparable quality C-Pol filters from other manufacturers to cost 1.5X to 2X as much as B+W XS-Pro C-Pol.
I agree with a previous response... Polarizers have their strongest effect at 90 degrees from your subject. To visualize this hold your hand like a gun, point your forefinger at your subject, then notice where your thumb is pointing... that's approx. 90 degrees. So when the light source (sun or ?) is anywhere along that arc, the filter will give maximum effect. As that angle increases or decreases, the filter will have less and less effect.. Ultimately it will have no effect when you are pointing directly toward the light source (0 degrees) or when the light source is directly behind you (180 degrees).
Because of this variation in the filter's effect, sometimes you may see a gradation in your images... Especially if shooting with a wider angle lens (shorter focal length, wide angle of view) and when there's a large, plain expanse in the image (such as a clear blue sky). This isn't necessarily a bad thing, but is something to watch for (you can usually see it occurring in your viewfinder).
There are times to NOT use a polarizing filter... such as when a reflection is an important part of the image. Also, if trying to photograph a rainbow, avoid any polarizer. It will make a rainbow disappear! And, because the filter has no effect anyway, I recommend removing the filter when directly shooting a sunrise or sunset, with the sun within the image. Providing no benefit, the added layers of glass in the filter will likely just cause flare problems (although when multi-coated flare may be minimized).
That said, circular polarizers remain one of the most useful filters you can have in your kit. Most other filters are unnecessary with digital photography. C-Pols are the single biggest exception. They can do things to images that can't be accomplished by camera settings or in post-processing software. (Neutral Density filters also remain useful, but are specialized... only needed for certain types of shots. And some people like to put a clear or UV filter on their lens for "protection", though frankly I find it a bit silly to think that a thin piece of glass can do much to prevent damage. Still I do use them shooting at seashore, to keep "salt spray" off my cameras. I'd also use them if I ever shoot out in a sandstorm or at a paintball battle.)
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
Tintype_18
 It is marked CPL. As I mentioned, the photos came out good where the fish can be seen without the glare.
John
