02-12-2020 09:34 PM
02-13-2020 09:57 AM
Could be too close or too dark or it's broken. Could be several things but you need to be more clear about how you used it and on what camera. What conditions? As much info as you can give.
02-13-2020 11:11 AM
@ebiggs1 wrote:Could be too close or too dark or it's broken. Could be several things but you need to be more clear about how you used it and on what camera. What conditions? As much info as you can give.
And if you have a Canon flash unit, make sure that "AF Assist Beam" is turned on.
02-15-2020 08:44 AM
@tsingi wrote:
my Canon 70-200mm F2.8 USM lens and the lens wont auto focus. It focus for the first shot and then struggles to focus ...
When I hold the shoot button half way, the lens is just focusing back and forth, and not finding anything to focus on.
Manual focus works perfectly tho, I bought it used online and i barely used it
If the lens cannot focus outdoors on a sunny day on something 20 feet away, then the lens is likely faulty.
02-17-2020 02:40 AM
02-17-2020 12:06 PM
