Advice for macro photos?
Tintype_18
To start, this is the lens I have, bought with a Canon T7 kit: Canon Zoom Lens EFS 18-35mm, 1:3.5-5.6 IS II; Macro 0.25m/0.8ft.. I have a number of opportunities for macro photography including my wife's flowers around the house. Also, bugs, etc., are around if I can get them to stay still for a few seconds. How can I "cash in"  with quality photos, using the settings on the camera; the T7 has a Macro setting on the dial. Manual or other setting? The 1:3.5-5.6 comes into play, I'm sure; best way to use them? Thanks for your help.
John
14 REPLIES 14
ebiggs1
First off nothing you have is capable of macro photography. It is pseudo macro if you will. You need a true macro lens for macro photos. The "Macro" setting on your T7 just optimizes close up focus and lens settings. It doesn't get you true macro.
With what you have as equipment, Photoshop, or lesser DPP4, will get you more close to macro pictures.
ebiggs1
The ratio of the subject size on the sensor to the actual subject size is known as the reproduction ratio. A macro lens is defined as a lens capable of reproduction ratios of at least 1:1
Tintype_18
EB, thanks and you confirmed my suspicions. I have heard of using a zoom lens to act as a macro. BTW, forgot to mention I have diopter lenses- +1, +2, +4, +10. I have stacked two for photos of trout flies. Your thoughts on this?
John
zakslm
Rising Star
Rising Star
John,
I have a T7 too.
I have used an EF-S 24mm f2.8 STM, an EF 50mm f1.8 STM, the kit lens and a EF 50mm f2.5 compact macro  with decent results.   The kit lens (the 18-55) surprised me because results were better than I anticipated, allowed focusing relatively close focusing and has IS (which helps).
I bought a used EF 50 f2.5 compact macro in order to try my hand with a real macro lens.  That lens (for me) produced some very satisfying results and I loved using it.  Unfortunately, the main board failed rendering the lens unusable. The lens was noisy, quirky and focused slowly but that didn't matter much for macro work.  It was also great for portraits  Even shooting wide open; it produced very sharp in focus details and in my opinion, rendered the best looking bokeh of any lens I own (including the EF 85mm f1.8 USM) . There are some shots I took with that lens that I've posted to the Gallery and if you wish, feel free to look them up.
What I learned thus far in dabbling in macro photography regardless of the lens was:
  1. I primarily used the center focus point only.
  2. I shot in AV or M adjusting ISO (within reason) so the shutter speed and aperture I wanted to use could be used.
  3. Results with the 50mm macro, 50mm f1.8 or the kit lens were best at an f7.1-f8 or smaller to expand the already very small depth of field for close-up and macro shots.  The 24mm produced good results at f4 or smaller.
  4. I tried to use a fairly fast shutter speed (particularly for non-IS lenses) to freeze subject or camera movement (a tripod helped too).
  5. I sometimes used an external flash with flash compensation at - 1 1/3rd (using the flip down Fresnel diffuser on the flash) or the built in flash at -1 flash compensation.  The extra direct illumination helped for subject not in direct sunlight.
When I nailed it, results exceeded my expectation.  I will probably look to replace the 50mm macro at some point in the future and I'm keeping my eye out for an EF-S 60mm macro USM.  There are other macro lenses out there  including 3rd party macro lenses that I’d consider as well.
Good luck!
LZ
Lots to consider and thanks for sharing your journey. Hmm. Used? Good idea. Will check to see if an EF 50 f2.5 compact macro is on the market. FWIW, I got my 18-135mm at a used book store, McKay's Books, for $98! Store let me bring the camera body to try it.
John
March411
Whiz
Whiz
Tintype_18, if you are looking to buy used KEH and MPB are trusted resellers and normally have good on hand inventory.
And I'll throw one more lens into the mix. I use the EF-S 35mm f/2.8 Macro IS STM and have had good results. It has a ring light in the lens which is nice, the only down side is battery life. Here is an image captured with the 35mm
Marc
Windy City
R3 ~ R5 ~ R6 Mk II ~ R50
Lenses: RF Trinity and others
Adobe and Topaz Suite for post processing
Personal Gallery
John,
Being in the right place at the right time has its advantages!  Your $98 lens is proof of that and use it well.
I bought the 50MM f2.5 macro on eBay from a seller based in Japan for a very attractive price including shipping that enticed me to pull the string.  When it arrived, it looked to be in excellent condition and the glass is flawless.  While shooting, the lens started giving me Err 01 intermittently, but for the most part, it functioned properly and results were good.  Then Err 01 started occuring more and more often until it froze up for good.  The seller was kind enough to refund my total cost which quite frankly was above and beyond what he had to do and certainly was much appreciated.
Most of my gear except the camera, kit lens and EF 50mm 1.8 STM is either refurbished or used.  I’ve bought and use gear from KEH and Adorama and bought used/refurbished gear from B&H in the past and recommend all 3.  Others recommend MPB and usedphotopro.com as well.  However, I still do occasionally scan eBay, garage sales, thrift stores, etc. in hopes of finding an elusive bargain that is “just too good to pass up!”
Good hunting!
LZ
FloridaDrafter
John, the first thing to keep in mind when getting a macro lens, or any lens for that matter but more important for macro, is that the minimum focusing distance (MFD) listed in the specs is from the sensor and not the end of the lens. This means if you have an MFD of 9 inches you have to take into account lens length and distance from flange to sensor, so you may end up being just 4 inches or less from the end of the lens to a skittish insect to get a true 1:1 macro shot. It also means you will be blocking light unless you are using a ring light, off-camera flash, or other moveable light source like a LED panel.
I have both the EF 50mm f/2.5 Compact Macro and the EF-S 35mm f/2.8 IS USM Macro.
The EF 50mm has a 1:2 or half life size (0.5x) magnification. To get true 1:1 Canon sold an adapter, the "Canon LIFE-SIZE Converter", to get you to 1:1, but it creates limitations when attached by: increasing the lens focal length to 70mm, reducing the maximum aperture to f/3.5, and limiting the focal range. Without the adapter, It does well for larger flowers and subjects that are 1-2 inches in size. This lens was produced in 1987, and although it has really good IQ, that (IQ) doesn't kick in until f/4 and really peaks at f/5.6ish, so it's not that great at it's native f/2.5. My wife used this lens on her Canon 35mm film cameras in the 90's and early 2000's and I used it a bit on my Rebels until I bought the EF 100mm f/2.8 IS USM Macro. I will add that this lens is slow to focus and really doesn't perform well on a modern camera.
The EF-S 35mm f/2.8 IS USM Macro is a true macro, but you really have to get close to get 1:1, which is 0.43 feet from the sensor, add lens and flange to sensor distance and you are really close to the end of the lens. The built-in ring light is only effective to about 6 inches from the end of the barrel, which is adequate for 1:1 macro and fairly small stationary insects but will take you out of 1:1. My wife bought this lens for her T7i and I have used it (and still do on occasion) on my 7D mark II with fair results, but I only use it on the 7D II for the built-in ring light when I don't have available light for my 100mm which is usually a unique situation, think spider or moth in the house at night 🙂 On its own as an all around lens (excluding macro), it is a nice lens with good IQ and seems to be sharp wide open, renders colors nicely, and has low distortion. But as with most entry lenses, it does get better as you stop down.
Just a reminder, true 1:1 or smaller macro lenses are designed differently to account for various distortions caused by shooting really close and is the reason they are usually expensive. Sorry for the long winded post, but I am very passionate about macro and come from an era where the lens made the macro and not post editing software. As I've said in other posts, you can make macro photos using just about any camera/lens combo in post, sort of, and I say that in reference to EB's comments, particularly "reproduction ratio". I know I've left a ton of crap out, but it's hard to remember it all when it's basically muscle or brain memory, if that makes sense 🙂
Newton
Found a couple of used lenses but in no hurry. March 411 has added another possibility to the list. Need to check finances and go from there. Thanks to all.
I'm amazed at the macro photos of insects, looking like something out of a B horror movie.
John
