11-20-2012 07:11 PM
It's easy enough to shift this lens left and right and merge the images to create a panorama. But, often the center and shifted images are vastly different in exposure, sometimes by a huge difference. What's this about?
11-20-2012 07:20 PM
When you shift the lens you are changing the composition of the scene in front of the camera. This will effect the metering and change the cameras setting. It's recommended to use manual settings so the exposure is the same across all the images.
11-26-2012 10:47 PM
11-26-2012 11:30 PM
Maybe its due to the type of metering are you using? e.g. spot metering picking up a really bright or dark portion of the frame?
11-27-2012 01:07 PM - edited 11-27-2012 02:10 PM
Hi, its a very well known phenomenon of a tilt and shift lens that a camera sets exposure incorrectly when using tilt or shift and you should always take a meter reading with no tilt and no shift and use manual settings. I have never found an explanation as to why but its true. If you google say 'tilt and shift exposure' you will find quite a few references to this, Incidentally I have found that the histogram in Live View mode gives an accurate indication of your exposure setting while using tilt and/or shift.
Also if you view http://www.youtube.com/watch?v=WLJyBlYdi5g at about 58 seconds you will hear it mentioned, although he is using tilt rather than shift but the same advise applies 🙂
11-27-2012 10:14 PM
Thank you. Strange but true. I'll change my exposure approach to the same one I use with other lenses for panos which is meter the center image and then set those values in manual mode.
