12-04-2012 07:12 PM
what is error 5100 for multifunction printeers and how do you fix it?
10-11-2016 02:28 PM
Hi maltaye,
The 5100 error can be caused by paper jammed inside of the printer, or a stay piece of paper / foreign object within the printer causing an incorrect signal to be sent to the main board.
1. Turn your PIXMA MG7120 off and disconnect the power cord and USB cable.
2. Remove paper from the automatic sheet feeder (ASF), in the back.
3. Gently pull jammed paper out, if any.
3-1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
3-2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
4. If the paper tears and a piece of that remains inside the printer, open the printer cover and remove the paper from inside the printer.
5. Check ASF with a bright light to check for obstructions. Remove any if found.
6. Open the rear cover to check if the paper is jammed.
7. Pull out the cassette and check if the paper is jammed inside the cassette area.
8. Load paper back into the ASF or cassette.
9. Reconnect the power cord, turn on the printer and confirm that the Alarm light is off. (If there was any jammed paper remaining in the printer, the paper may be automatically ejected.)
If the above procedure does not resolve the 5100 error, additional troubleshooting would have to be performed and your PIXMA MG7120 may require service.
If you continue to have difficulties, please contact our support group using the following link:
https://www.usa.canon.com/internet/portal/us/home/contactus
11-01-2016 03:52 PM
11-01-2016 03:52 PM
12-12-2016 10:43 AM
12-14-2016 08:41 AM
Hi PurpleFX,
It is recommended that you contact live technical support. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
A Technical Support Representative will be able to resolve this issue faster.
12-26-2016 09:38 PM
12-26-2016 09:49 PM
01-20-2017 12:31 AM
My printer reads support code 1500. I had a paper jam when I received this code. I removed the paper that was jammed in the printer. I have turned off my printer off 10 times, cancelled the printing orders that was pending when I recieved this code. It is giving me Support code 1500 and gives me 3 steps. I did remove the paper that was jammed, I ensured that there was no objects jammed into the printer and turned it off several times.
I have used a flaslight to ensure that there is no objects jammed in on both sides. I load the paper into the tray and turn on the printer. The printer makes a weird sound and the support code 1500 will not go away no matter how many times I turn it on and off.
All I currently, know at the moment is that my print is a Canon and I am using ink cartridges 251 XL. I am currently at work and not able to provide the model number of the printer. I am done my shift at 5:45 am and will be home around 6 - 6:30 am if you require further information.
Can you help me to get rid of the code?
01-20-2017 12:42 AM
01-20-2017 12:38 PM
Hi Gumba3,
We can assist you with clearing the 1500 error, but we would need to know the model number of your Canon printer.
Once we know this, we can assist you further.
