12-04-2012 07:12 PM
what is error 5100 for multifunction printeers and how do you fix it?
01-21-2017 06:33 AM
It is a Canon Pixma 5520
01-21-2017 06:36 AM
My printer is Canon Pixma 5520
01-21-2017 10:38 AM
Hi Gumba3!
For an Error Code 5100, follow the steps below:
01-22-2017 12:11 AM
I did try those steps and I was still getting that signal. Thank you for help. I appreciate your help. When I got home and attempted to use my scanner. The issue resolved itself. I am able to print without having any error codes.
02-19-2017 04:53 PM
@WarrenSmith wrote:what is error 5100 for multifunction printeers and how do you fix it?
03-23-2017 12:14 PM
CANON PIXMA MG3550
03-26-2017 06:19 PM
Model # for Cannon PIXMA printer is MSDuo SD MS
03-26-2017 06:22 PM
04-04-2017 07:58 PM
How do I fix my 490 error code 5100 on my printer
04-05-2017 04:42 AM
Hi Henriettamcdowe,
The 5100 error is an indication that your PIXMA MX492 is experiencing an internal error. To try to resolve the 5100 error, please follow the following steps:
1. Turn the unit off using the power button.
2. Lift up the scanning unit (printer cover) then place the scanning unit support into position.
3. Remove any orange protective tape and the protective material that may be present.
4. Please check for jammed paper:
4-1. Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
4-2. If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it. Be careful not to touch the components inside the machine.
5. Lift the scanning unit (printer cover) slightly to set the scanning unit back to its original position and then gently close scanning unit.
6. Reload paper on the multi-purpose tray.
7. Press the power button to turn on your MX492.
8. If the Alarm light remains on after powering up the MX492, open the cover again.
9. Remove each cartridge.
10. Unplug the power cord from the back of the PIXMA MX492.
11. Reconnect the power cord and turn the unit on.
12. Reinsert the cartridges.
13. After the cartridges have been reseated, close the cover.
14. Fan a new stack of paper then try to print again.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
