06-25-2015 02:20 PM
I am scanning several images together against a background. They automatically come up as pdf files. I want a jpeg file. I have done several of these kinds of composites and at first they were jpegs but now they are all pdf files. Is there a setting somewhere that I am missing. Thanks for any help.
05-07-2020 11:17 AM
Thank you for replying.
I am not in the US so will use other site if needed.
My printer is TS3160 and I am using Windows 10.
Thanks
05-07-2020 10:53 PM
Ah if only it were that simple. I have this Canon because the Epson I purchased was terrible. Every time I turned on I had to reconnect to Wireless, then it would not scan from the printer to computer, but would occasionally scan from the computer to the scanner if I could find the dialogue box. There were so many downloads needed for drivers and utilities it was mind boggling. Contact with Epson even allowing them remote access did nothing.
So I returned it to where I purchased and they said it would be within three months to fix it. Well I put on the sad face and explained I had a University assignment on Photography to have in by Friday, so they felt sorry for me and gave me the cheapest they had - a Canon.
What happened to plug it in and it worked?
I had a Brother A3 for 10 years and the cogs wore out, should have had it repaired..................hindsight is a wonderful thing.
Thanks for your input!!! and good luck with your photography.
06-23-2020 11:59 AM
I have found the best solution to this problem, took my hammer to mine and smashed it in one hundred pieces then bought another brand, never buy canon again!!!!
06-25-2020 01:48 AM
08-12-2020 07:39 PM
I have a TR850 and would like instructions on how to change how the image is being saved both on the canon machine itself, with IJ scan utility and Windows 10 if possible.
My scanner used to interpret the images accurately, meaning, a photo was saved as photo, as a jpg and opened in photo viewer, where I could then crop it and save where I wanted on my computer.
Note: I scan images by placing the paper in the scanner and pressing scan on the machine. - I do not pull up the IJ scan utility program on my compuyter to proceed with scanning, unless the scan button on my printer TR850 doesn't work.
Now, almost all images are being saved as pdf and as such I cannot crop the image before saving. My printer/scanner used to interpret images correctly (photo or document), would save as pdf or jpg and as such the appropriate program would open (photo viewer or adobe) up on my computer when I went to save the document/image scanned.
I have spent significant time searching for solutions and have come up empty.
I would appreciate any insight or possible solutions with details and instructions on how to
1) have my images saved as a jpg when using using the buttons on the machine itself;
2) have images open with photo viewer on my computer when the printer/scanner has communicated with my computer that the scan is complete and I open the image on my computer; (Note: I'm not sure that setting my default program to Photo Viewer works for this problem);
3) be able to save documents as pdf or word.
Canon Garden Viewer does not allow for me to crop the picture and I am not sure if all my images are saved there that I scan. I do not know if my scanned images are being saved in multiple locations - my computer and Canon Garden Viewer - and could use insight on how to solve this as well.
08-13-2020 08:10 AM
Boudica1, I have a TS8150 and W8.1. When scanning, 'save to computer' I now always scan as 'photo', rather than Doc or Autoscan, which are the 3 choices my 8150 offers on its screen. Doc puts them as a jpg into Documents with an 'IMG_0000 number which never shows up on the thumbprint search, but does if you do "Search jpg" along with every other jpg in there! Auto Scan seems to put everything into 'MP Navigator EX' as a PDF, but Photo always loads them into 'MP Navigator EX' as a .jpg. I find scanning from the computer cumbersome as the 3 computers are in different rooms to the scanner/printer Hope this helps you.
10-07-2020 10:30 AM
I have the same problem,I have a Canon Pixma MG 5750 and my PC is running Chrome and Windows 10 any permanent fix?
Dave.
01-25-2021 03:23 PM
Similar problwem - I weant JPEG but keep haviong my scans result in PDF files.
01-25-2021 03:26 PM
11-16-2021 04:21 PM
