05-21-2013 09:17 PM
I have canon inkjet office all in one at home, mx432, mx439 series. When placing paper in while printing all the paper got pushed in and now is stuck. How do I fix this?
05-26-2013 11:25 PM
Hi efelicia,
Please try the following steps to remove the jammed paper:
Important:If a USB flash drive is inserted in the direct print port, remove it before you stand the machine. Stand the machine on a wide and flat surface such as a desk. When you stand the machine, hold it securely and be careful not to hit it on a hard object.
4. Push the open lever to open the transport unit.
When you open the transport unit, support the machine with your hand so that it does not fall down.
Reference:
If the paper is rolled up and it is difficult to remove, grasp the edges of the paper, then remove the jammed paper. If you cannot remove the jammed paper from the transport unit, close the transport unit, stand the machine upright, then open thepaper output cover to remove the paper.
Reference:After you close the transport unit, do not keep the machine standing upright.
