my canon mx892 will not print because of error U052.
markmarn
our canon mx892 will not print due to error U052.  i followed all of the suggested steps for this problem related to an MX700 but it did not correct the problem. now what?
43 REPLIES 43
Hello all cannon victims ,  I had a MX 715 series and out of the blue up pops the error message U0562, now I followed the recomended  advice (remove the ink cartriges blaa blaa)  with out success +multible attempts later decided that this must be a built in destruction point to cause users to have to purchase a new printer.
I cannot believe that so many others people have had this same problem with no fixes that have worked for this not to be so.
I think this destructive problem should be investigated by relevent authorities  starting with the relavent ombudsman.
I would join any online group capable of investigating this problem
 Joe Sang  victoria Australia
Hello, I would be so grateful for a solution to this U052 error problem.
I have removed the printhead, cleaned all the parts, soaking the print head in water till the water ran clearn.  Cleaned the cartridges with alchol and still nothing works, do you have a solution?
Many thanks,
Yvonne
I unpluged the printer, removed the printhead and cleaned the gold contacts with rubbing alcohol. Then I wrapped a piece of 400 grit sandpaper around my finger and lightly sanded the pins inside the printer that contact the printhead. When I put it all back together and powered up the printer the U052 error was gone. We'll see how long it lasts.
The fix didn't last long. I'm getting it again.
