08-10-2013 08:48 PM
our canon mx892 will not print due to error U052. i followed all of the suggested steps for this problem related to an MX700 but it did not correct the problem. now what?
08-13-2013 01:46 PM
I have replaced the printhead, following your instructions, several times but the error message still occurs and will not let me even use the menu button. The red light on the "M" ink cartridge blinks slowly instead of staying on solid. By the way, your instructions left out a step: remove all the ink cartridges before lifting the print head lock lever.
This error message came on as i was using the printer to print and i had not removed the print head or replaced any cartridges.
08-12-2013 09:58 PM - edited 08-12-2013 10:00 PM
Hi markmarn ,
Please try the following procedure to reseat the print head and inks:
Install the Ink Tanks
Make sure that the position of the ink tank matches the label.
Press the mark
(Push) on the ink tank until the ink tank snaps firmly into place.
Make sure that the ink lamp lights up red.
If the error returns, the printer may require service options. To hear about your service options, please click the following link: Contact Us.
Thanks!
08-13-2013 01:46 PM
01-03-2014 11:11 PM
I have the same problem, had never take the print head out or used non-Canon ink. Does anyone have any other solutions?
02-03-2014 11:56 AM
See the posts in the Personal Printer forum. Join the class action suit
02-14-2014 05:01 PM
04-27-2014 11:35 AM
reposting a fix that does not work is insulting. This is a cronic problem and Canon is just letting us twist in the wind.
04-27-2014 04:39 PM
Has one person come back to you saying the your post helped them???? I bet it's zero. pretty insulting
05-02-2014
11:35 AM
12:27 PM
Stephen
I had this error with my canon printer that showed up one day with no warning.
Using my powers of deduction and understanding how power supplies work I found an easy solution to fix that that anyone can do in about 1 minute.
If you would like to know how to do it email me.
Removed email address per FORUM GUIDELINES
09-01-2014 12:32 PM
So, is canon doing anything about this? I've only had this printer for 16 months and have never had this issue on any other unit before. What's up canon?
