02-13-2016 09:13 AM
02-15-2016 10:06 PM
Hi edj, and thanks for that information.
The first step to take with any print quality issue is to perform a nozzle check. Instructions can be found HERE.
There should be a black grid pattern at the top, and several color bars below that. If the grid or any of the color bars do not appear, further cleanings may be necessary.
I try to avoid deep cleanings until absolutely necessary, because they consume extra ink. There is, however, a technique I've found that can clear many stubborn clogs.
1. Run two deep cleanings in a row (do not perform a nozzle check afterward.)
2. Leave printer powered on overnight.
3. Perform a standard cleaning the following day.
The ink from the deep cleanings act as a solvent on the clog, allowing it to be cleared the next day.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
02-13-2016 09:28 AM
Hi edj!
Welcome to the Canon Community Forums!
So that the Community can help you better, we will need to know about any error messages you're seeing, and the Computer Operating System you're using (Windows XP/Vista/7/8/10 or Mac 10.x), as well as the way you connect to your printer (USB or networked via WiFi or Ethernet).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone during the week or anytime by email.
Thanks and have a great day!
02-13-2016 09:58 AM
I am using win 10 and connect by wifi. I can't even copy a domument using the mx 722. Only get a blank page for any action whether I am printing from the computer or the mx722. This just happened without any warning or error messages. Have tried cleaning and deepcleaning and realignment with no results. The scan function works ok.
02-15-2016 10:06 PM
02-21-2016 09:18 AM
Thr black 250 PGBK was clogged and had to be replaced. The cleaning didn't remove the clog however the attempted cleaning is the correct approach before replacing.
edj
