09-07-2014 08:53 PM
I try to print with iphone, but alway got this no paper in upper tray error ( I have paper in lower tray), looks like this is a canon software issue, if I can not resolve this, I will need to return this product, this is only two days old.
thx
08-10-2016 08:42 PM
I finall found a way to print from iPhone photo album.
1. Selec the picture(s) you want to print.
2. Select Save PDF to iBooks
3. Print from iBooks
Hope this helps.
08-10-2016 08:43 PM
Hope this helps.
09-06-2016
11:03 PM
08:15 AM
Just tried this and it works, thanks. Customer support is closed now but I will be calling them first thing in the morning..if there isn't a fix to this issue its getting re- boxed, labeled and sent back.
09-07-2016 12:02 PM
I wish I had read this thread before purchasing the printer. It was fun listening to Canon trying to deflect the problem to Apple. Sure, like I need another app on my devices to make up for the shortcomings on your product ?
09-19-2016 06:35 PM
I have had the same problem. The solution "Save PDF to iBooks" works. Specifically, I want to print a screenshot from my iPad, getting the common error of no paper in the upper tray. The Canon help rep said that the iPad interprets the screenshot as a graphic image, sending it to the printer via AirPrint. All incoming "graphic images" are classed as 4 x 6 inch requests and ported to the specialty upper paper tray. All discussions with the rep about the iPad app selection of 8.5 x 11 inch letter paper fell on deaf ears. Apple AirPrint was blamed for this problem. No Canon responsibility for fixes. I asked if all Canon printers have this problem with Airprint, but no answer was provided. This is a workaround, not the proper solution from Canon.
09-19-2016 06:51 PM
09-23-2016 01:32 AM
mx922 printer fails due to "no paper in upper tray"
09-23-2016 01:37 AM
MX922 PRINTER FAIL DUE TO "NO PAPER" IN UPPER TRAY
09-23-2016 01:39 AM
12-20-2016 08:25 PM
Absolutely solved my issue. Was not on letter. Now all my device print wirelessly and beautifully. iPhone, iPad, and both our MacBooks. Thanks.
