mx920 document in ADF
Teresinha
Hello, my scanner is not working : there is always a message indicating "document in ADF", "press OK".
The printer works fine though.
6 REPLIES 6
Stephen
Moderator
Moderator
Hello!
So that the Community can help you better, we will need to know the Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
If you're in the United States, and this is an urgent support need, please click HERE to enter your product information and discover your support options.
If you're outside of the USA, please click HERE to find support options in your country.
Thanks and have a great day!
Hello, I use a MacOS 10.14.3 and wifi... Thank you !
If the printer "thinks" there is a document insert into the ADF, then one of the following is probably true:
Door isn't closed
Sensor is dirty or failing
Physical debris or paper present
This is a mechanical error.
Thanks - but the message only comes after page 1 or 2...
Big difference between " there is always a message indicating "document in ADF"
and
inspect and check the ADF for foreign debris, worn rollers or feeders, binding, any old remnant pieces of torn paper.  Best way to clean is with canned air and a Q-Tip dipped in alcohol.  Some of the grears / components might have a light coating of white lithium grease.  If in doubt, don't apply unless you are absolutely sure.
The paper width must also be set evenly and straight.  First page feeds, send can jam if not aligned correctly.  Also suggest you fan the paper before inserting and adhere to the max number of sheets the ADF can be loaded with.
Hi Teresinha,
If the message still wont clear after checking and cleaning the adf, troubleshooting with our support group will be needed to narrow down the cause of your issues. Please contact our support group at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST(excluding holidays).
