08-23-2014 12:03 PM
mg5320 won't print. Nozzle check only shows cyan and magenta. New cartridges, no error messages. Simply goes through the motions and won't print. Machine is only about a year old...
08-26-2014 10:17 AM
Hi maricota,
Because performing deep cleanings did not get the nozzle test to print correctly, it is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
08-23-2014 12:21 PM
08-23-2014 12:25 PM
The printer is connected with a usb cable to a pc running Windows7 Professional. Two laptops connect wirelessly to the printer and also run windows 7.
08-26-2014 10:17 AM
Hi maricota,
