mf8580cdw will not print labels
williambartel
mf8580 will not print labels, thinks it is out of paper. I can print the labels on regular paper, but when I insert the labels-nothing.
5 REPLIES 5
Tiffany
Moderator
Moderator
Hi Williambartel!
So that the Community can help you better, we will need to know what Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
Thank you Tiffany for responding,
I have Windows 7. I have spoken to technical support to no avail. I was told I may need to download a driver. I do not have any issues printing Word documents,(Word 2007) just the labels. When I try to print labels created in Word, the printer errors and thinks there is no paper in the tray. I can see in Word where the label information is being sent to the printer. When I checked the printer to see where the document was, there is nothing in the printer queue. Also the labels are merged from a dental database called Dentrix. Everything else regarding the printer works just fine.
Thank you in advance for any suggestions.
Hi williambartel.
I will be glad to assist you.  To print labels from the MF8580Cdw, please follow the instructions below:
1.  Press (Select Paper/Settings).
2.  Scroll to [Paper Settings], and then press [OK].
3.  Scroll to [Multi-purpose Tray], and then press [OK].
4.  Scroll to [ON], and then press [OK].
5.  Scroll to [Paper Settings], and then press [OK].
6.  Scroll to [Multi-purpose Tray], and then press [OK].
7.  Scroll to [Set Details], and then press [OK].
8.  Scroll to [LTR], and then press [OK].
9.  Scroll to [Labels], and then press [OK].
Next, print your label document from the computer.
I hope this information is helpful to you.  Should you experience any issues or need further assistance, please contact us at 1-800-OK-CANON (1-800-652-2666).
Thank you for responding. This did not work. When I hit the print button in Word, the printer beepd and the message is "no paper". I tried several times. Same result.
Thank you for your reply.
At this point, I recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).  Although the forum may be your preferred method of communication, the real-time feedback that is available with our telephone support group will be very beneficial in this case.
