how do you change from letters to numbers on keypad
nanagigi
2 REPLIES 2
Jenine
Rising Star
Hi Nanagigi,
To have a better understanding of your issue, please let everyone know what printer you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/EmailCanon or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
jrhoffman75
This might help
Press the SETUP button on your printer's control panel.
Using the arrows, select DEVICE SETTINGS, press OK.
Select LAN SETTINGS and press OK.
Select Wireless LAN Setup and press OK.
If a message appears to press the WPS button, press STOP to cancel.
Select STANDARD SETUP from the next screen that appears and press OK.
Highlight your access point or router and press OK.
Press OK again to confirm the access point name.
Enter your passphrase using the keypad to the right.
At the screen where you enter your passphrase, in the top right corner of the LCD screen you should see a :1 . This indicates that you are in numeric entry mode. If you press the asterisk key (*) it will switch to :A or uppercase letter mode, pressing asterisk again with switch to lowercase letter mode. To enter a letter in either letter mode, you will press the associated number key to cycle through the available letters. For example: To enter a letter "c", you will press the "2" key three times.
Press OK when done.
The LCD screen will say "Connected" if the password is correct.
