11-07-2012 02:11 PM - last edited on 11-07-2012 11:34 PM by Naomi
How do I fix an error code b200 on MP560
06-29-2018 10:29 PM
opening the cover just after turning it on before the error could pop up, waiting for the cartridges to move out about 1/3-1/2 of the way out then shutting the cover. Did the trick after isopropanol cleaning did nothing. So thank to whoever it was above who shared that tip!
Just finally got around to buying ink and it wasnt cheap. so glad this isn't a throw it out issues. yay for me, yay for the environment.
06-26-2019 10:09 PM
Thank you!!! I have an MG7120 and I accidently unplugged wrong cord, to my printer and came into this error code b200. This worked. The call for assistance # provided was useless.
07-11-2019 05:31 AM
07-11-2019 08:28 PM
I'm adding to this, your fix actually ended up NOT working, when I went to print the same error popped up. I had to actualy throw away the printer and buy a new one!
07-18-2020 04:51 PM - edited 07-18-2020 04:56 PM
OMG, how did you even figure this out?!?! I followed your steps, and it worked FIRST TRY. I'm stunned. I award you all the internets!
Thank you bebebeck!!
EDIT: It is only a temporary solutions, since I'm getting the error again, but its great if you need it to print one time.
03-10-2021 05:44 PM
to hiyjnx80 - You couldn'thave said it better. Canon makes money on ink and they sell fairly cheap machines, although I must say that I have had my PIXMA iP4800 for quite a while. It's the same thing that Eastman Kodak did with film and cheap cameras.
The cost of these printers should relate back to the negative externalities that the companies generate - they are the ones who should pay for repurposing/recycling their products, and not private or government organizations.
BTW I have tried everything listed on every website that I could find, including yours (even replacng all the last switch out of an ink cartridge). Nothing worked. And unfortunately mine is not a scanner also, so your final fix was not possible.
I have a call into their "help" line but who knows... they will probably say the same thing to me - buy a new printer. And this is just after I purchased a new supply of inks - 2 of each, some of which I have opened.
Thanks for your detailed instructions. Just wish they had worked.
03-10-2021 05:45 PM
03-10-2021 05:50 PM
03-10-2021 06:27 PM
03-10-2021 06:30 PM
